Oziexplorer question
Submitted: Thursday, Oct 19, 2006 at 08:56
Willem
In have had Oziexplorer for 4 years now. I have only used it when driving some extreme tracks with Moving Map and for most of the time it languishes in my laptop.
I need, however, to do a bit of mapping for a friend.
Yesterday I went out to refresh my memory, fired everything up, drove a distance, and saved waypoints and track to file. File is stored in Oziexplorer Data.
When I go in to Data and put the cursor over the icon it shows the start of the maps in there. If I click on the data icon the box comes up blank.
If I go to Save to File the dialog box opens with all the saved maps in it. If I click on a map it says it doesnt know which program created it and when I go into my programs there isnt anything recognisable.
Anyone have aby clues to this mystery?
I have gone to HELP file(if all else fails read the instructions..yes I know) but my older brain does not understand half of it. I am having a mental block!!!....lol
Reply By: Member - Andrew (QLD) - Thursday, Oct 19, 2006 at 09:12
First thoughts are a file association issue.....don't know why though.
Have you confirmed that the track file has a "plt" extension to it and the waypoint has a "wpt" file extension?
199790
Follow Up By: Willem - Thursday, Oct 19, 2006 at 10:09
Thanks Andrew
Yes.
I suppose I might be trying to do something that isnt possible
458790
Reply By: Footloose - Thursday, Oct 19, 2006 at 09:16
Willem, have you tried opening the original map and opening up the waypoints ? Probably a silly question but I have a head full of sinus today and hence I'm more silly than normal :))
199791
Follow Up By: Willem - Thursday, Oct 19, 2006 at 10:10
Yes Footy, am in there now
Sinus is a bugger but doesn't worry me. I have asthma.
458792
Reply By: Troop-a-dour - Thursday, Oct 19, 2006 at 09:16
I assume you saved the waypoints on the GPS as you were travelling??
Then under Magellan- 'Get Waypoints from GPS'. I think they are then displayed on the map- then you could 'Save Waypoints' to your normal file.
199792
Follow Up By: Willem - Thursday, Oct 19, 2006 at 10:12
Thanks Troop
No didn't save the waypoints to the GPS but on the map instead. Yes am aware of the function.
458794
Reply By: Member - Andrew W (SA) - Thursday, Oct 19, 2006 at 09:27
After firing up OziEx you need to:
1. Load the map
2. Load the previously saved Waypoint File(s) - *.wpt file
3. Load the previously saved Track File(s) - *.plt file
You may find that you want to change the track colour (select the little rectangle icon that brings up the tracks list, then select the particular track and change it's colour) so you can see it on the map.
Then you can also then edit the Waypoints (for instance) ... and save your edits back to the file. This might include moving the waypoints to perfectly align with the map; editing the style and icon and text etc.
I do this all the time - I use the Man overboard feature to create the waypoints as I am driving. Note them down in a notebook, and come back to them later and change them to reflect the feature I wanted to note on the map.
I hope this helps (but I haven't loaded up OziEx so am working blind)
If you're down in
Adelaide soon, let me know and you can drop by and I can show you.
Andrew.
199793
Follow Up By: Troop-a-dour - Thursday, Oct 19, 2006 at 10:00
What happens if you have a MOB when you're using the MOB function to save waypoints???
You wouldn't know where to go back to pick up you're lost passenger !! (although some pax might be better off left)..
458785
Follow Up By: Member - Andrew W (SA) - Thursday, Oct 19, 2006 at 10:10
I use the KOP function (kicked out passenger) function for those requirements.
Just for journalistic purposes of course - once kicked out, always kicked out.
458791
Follow Up By: Member - Andrew W (SA) - Thursday, Oct 19, 2006 at 10:11
for the record, MOB allows you just to do a Ctrl-O (oh not zero) and nothing more to record it.
458793
Follow Up By: Willem - Thursday, Oct 19, 2006 at 10:16
Thanks Andrew. I did just that. I have part of the track saved as a .plt and part of the track as a .rtf. Dunno how I did that. I think I will go out again later today and try again.....lol
No won't be in the Little Smoke(
Adelaide) for a while but we will catch up sometime when this other project is completed.
458796
Follow Up By: Pajman Pete (SA) - Friday, Oct 20, 2006 at 07:34
The problem with using MOB ([ALT] O) is that it start navigation working and keeps updating a direct track back to the waypoint. Try dropping markers ([ALT] K) instead. They are a little easier to see on the map as
We use them to record where we have taken photos. When you get back from a trip with >600 digital shots it can be hard to remember where they were all taken. The markers (waypoints) have a date time stamp and you can recover the original shot time of the photo from the EXIF data with any number of free viewers.
Pete
458941
Follow Up By: Willem - Friday, Oct 20, 2006 at 07:56
Thanks for the info Pete
As an aside.....we took 2500 digi pics on the last trip. I download the pics every night on to the laptop and then clear the camera. I make folders from one point to the next...i.e.
Coober Pedy to
Alice Springs and then load the pics into that folder. I make sure the folder doesn't become too big. After each folder has been filled I burn it to disc as a back up. This way it is easier to remember where the photo was taken. Once home I make the time to name all of the pics.
458947
Follow Up By: Pajman Pete (SA) - Friday, Oct 20, 2006 at 08:51
I love digital! We seem to average about 140 shots a day when wandering. Less if we are trying to get somewhere. I never used to do a fraction of that when I had to pay for film and processing.
The other issue these days is that no-one stocks much film. I was in a
shop in
Halls Gap last week and a bloke was trying to buy some 400 ASA colour film and they were out. What do you do for holiday happy snaps then?
I now carry 2 XD cards in my camera bag which can store nearly 1500 shots before I need to flash up the laptop. Even so we still do the evening laptop download and because I am always suspicious of technology we also backup to DVD or memory stick.
I have trouble finding time to name them all when I get back, so I save the marker waypoints into the same directory as the photos, that way if I leave it to long to do the naming I can just flash up Explorer, load up the waypoints and refresh my memory.
Pete
458958
Reply By: 4_Runner - Thursday, Oct 19, 2006 at 09:29
When you say "If I click on a map it says it doesnt know which program created it", do you mean that you are attempting to open the file, expecting it to open up in OziExplorer, but it gives you an error message?
And when you say "when I go into my programs there isnt anything recognisable", do you mean you cannot find the Oziexplorer program anywhere under "Programs" on the Start Menu?
If so then it sounds to me like you no longer have OziExplorer installed, or that something else has interfered with it causing it not to run properly.
Either way I would suggest you will need to re-install the software.
Goto start -> Settings -> Control Panel -> Add or Remove Programs
Look for OziExplorer on the list. If it is listed, select it, then click the "Remove" button to uninstall.
If it is not listed, then it means it is not installed on your system.
The next step is to re-install OziExplorer.
Hope this helps.
199794
Follow Up By: Willem - Thursday, Oct 19, 2006 at 10:19
Thanks 4_Runner
No, Ozi is installed OK. I think that I have been trying to do things the wrong way. All the advice here has helped to 'rejuvenate' the memory....LOL
Will go for another drive and sort things out a bit better and then report back tonight.
458797
Reply By: Member - Andrew (QLD) - Thursday, Oct 19, 2006 at 09:46
Throwing another idea into your already full memory-banks:
If you have the "Log Track to File" selected in the Moving Map menu, then you should have the track stored as a file automagically called mmTrack.plt (or another name if you have changed this option). This file will grow in size, every time you have a new session of MM, as it appends the data to the end of this file. This saves the problem of forgetting to save the trackfile, or loosing
battery power etc.
Open this file to
check for your recent track if you cannot find it otherwise.......be aware that "showing the tracklist" of any trackfile over about 5-6000 trackpoints in Ozi will cause it to bog down to the point of requiring a closing of the program.
Enjoy
199797
Follow Up By: Willem - Thursday, Oct 19, 2006 at 10:23
Andrew, thanks again
I have everything stored correctly but it seems that I have been going about things the wrong way, trying to open files without having the map open in Ozi.
I think I need to store all the information to file and then email those files to where they need to go and then that person will have all the data needed.
458798
