Brisbane Auto Elect?
Submitted: Thursday, Oct 19, 2006 at 09:38
ThreadID: 38622 Views:3345 Replies:5 FollowUps:4
Looking for an auto electrician and thought I'd utilise the Exploroz 'yellow pages' again.
I'm looking for someone on the northside of Brisbane who understands or is familiar with working on vehicle solar installations, battery monitors/chargers/isolators, agm's etc.
Don't know where the problem is in the system but the xantrex battery monitor says the rotronics system is not charging the agm's. There is no warning light on the rotronics.
Plugged in the C-tek, which is hard wired to the batteries, and it is working and charging the agm's, according to the xantrex monitor.
Reply By: Trevor R (QLD) - Thursday, Oct 19, 2006 at 12:11
Hi John,
You could try Foy's at Nundah, PH 32668888 I see a lot of Motorhomes in there so I presume this would be right up thier alley???
They have done a few jobs for me and thier work is OK (not outstandingly neat but OK) but they always fix the problems for me.
Regards, Trevor.
AnswerID: 199820
Follow Up By: Member - Ozdyssey (QLD) - Thursday, Oct 19, 2006 at 21:28
Thks Trevor
booked in for Monday.
FollowupID: 458908
Reply By: troopyman - Thursday, Oct 19, 2006 at 12:46
www.springers.com.au/default.asp
Just over the gateway bridge(free at the moment in peak hour i believe).
AnswerID: 199824
Follow Up By: troopyman - Thursday, Oct 19, 2006 at 12:47
Hey theres a springers at strathpine as well .
FollowupID: 458814
Reply By: Mikee5 (QLD) - Thursday, Oct 19, 2006 at 18:30
I took my caravan to Solar Panel Xpress at Caboolture (ph 1800 800 846). They fixed the problems I was having with solar charging. Apparently people go there from all around Australia. No affiliation, just a happy customer. Don't forget ABR although he is on the Southside he is a site advertiser.
AnswerID: 199872
Follow Up By: Member - Ozdyssey (QLD) - Thursday, Oct 19, 2006 at 21:34
Bugger forgot they moved to Caboolture.
FollowupID: 458914
Reply By: Alloy c/t - Thursday, Oct 19, 2006 at 18:45
What model Rotronics are u using ?? know that when we went solar ours was incompatible with the solar regulator ,basicly "cooked " the rotronics , recomend the 12volt shop / Springers at Strathpine.
AnswerID: 199874
Follow Up By: Member - Ozdyssey (QLD) - Thursday, Oct 19, 2006 at 21:32
Alloy
What do you mean , how did it 'cook' the rotronics.
I forget the model rotronics but up until now it has all been working fine for the last 6mths.
FollowupID: 458913
Reply By: Member - Andrew W (SA) - Thursday, Oct 19, 2006 at 21:32
Derek Bester is at Belmont - highly recommended.
He is an advertiser on this page too ;-)
AnswerID: 199921
