Mechanical Question 80 Series
Submitted: Friday, Oct 20, 2006 at 08:10
Member - Karl
I am after some assistance. I am after the size of the sump plug on the 1 HZ motor as I am going to do my own oil changes and I want to make sure I have the right size of socket/ring spanner before I start.
I would be greatful if someone could let me know.
Thanks - Karl
Reply By: Robnicko - Friday, Oct 20, 2006 at 08:47
Karl,
Most likely a 14mm
Rob
199966
Reply By: Kiwi Ray - Friday, Oct 20, 2006 at 09:12
Hi Karl
Make sure you fit a new fibre washer each time, it saves oil leaks.
They are only a few cents each
Ray
199975
Reply By: Member - Phantom (WA) - Friday, Oct 20, 2006 at 10:24
Hi Karl,
The original sump plug on my cruiser had a very shallow head and stripped very easily, especially if you use the wrong size socket. The replacement ones from Toyota are much deeper and I would suggest it a good investment to get a new one, if only for a spare. As above, always replace the washer.
Steve
199991
Reply By: Member - Davoe (Nullagine) - Friday, Oct 20, 2006 at 11:53
zFrom memory they have a decent head on them i just use a shifter. For the g/box, tc and diffs however you need a 15/16ths preferably 6 sided socket as usually the last boofhead has tightened the crap out of them and they have a thin fragile head
200004
Reply By: Member - DOZER- Friday, Oct 20, 2006 at 16:28
14mm......oh and dont forget to screw the 710 cap back on after you fill it up
200044
