Cooper ST Noisy when old ???
Submitted: Friday, Oct 20, 2006 at 19:56
ThreadID: 38671 Views:3202 Replies:3 FollowUps:7
Hi to all
I need new tyres and are heading to Cooper ST or ATR .Mainly used around town and towing Caravan up beach and little 4wd with club.Ive been told ATR's will be quite to the end and ST get noisy at 50-60.000 km.Both tyres are Lt .
Thanks Mark
Reply By: Member - Norm C (QLD) - Friday, Oct 20, 2006 at 20:13
Mark, I've used both.
When I got the new Hilux, I had ATRs fitted. A good tyre. No road noise. Excellent on road and on sand. Adaquate off road.
When preparing for a Kimberley trip with over 6,000 off bitumen, I decided to swap to STs and standardise between vehicle and CT. I slightly increased tyre size at the same time. I bought 9 STs (4 for veh, 2 for trailer and 3 spares).
The STs are much noiser on bitumen, a good on road tyre, but not as good as the ATRs IMO. But off road, the STs are much better. They are an agressive AT. They self clean very well in mud and give great traction on rocks, dirt etc (for what is essentially an AT tyre).
With your description (mostly road, with some sand and a little off road) the ATRs may be the go. All depends on what you want in off road performance and how much you are prepared to give up to get it.
I'm very happy so far with the STs, but was after reasonable off road performance and most of our trips include a fair bit of dirt driving.
AnswerID: 200087
Follow Up By: markcas - Friday, Oct 20, 2006 at 20:43
Hi Norm
When iam towing my 17ft van up the beach iam getting stuck in soft sand.my mate has MTr's and seems to float over it easier my tyres spin and his bite in.The vehicle is a Pajero diesel.After seeing how his tyres work the soft sand is why iam looking to go the ST but if you could hear them with the window up i wouldn't be happy
FollowupID: 459104
Follow Up By: D-Jack - Friday, Oct 20, 2006 at 20:47
Marcas, from my experience more agressive tread work better as long as there is firmer sand underneath to bite on. If it's all soft stuff, particularly on steeper sloping areas, I reckon the more agressive treads are a liability as they dig downward. sometimes the wheel spin will keep you higher on the sand pile. I'm waiting for the punches to start flying now!
D-Jack
p.s got 10 ply ATRs (245/75/16) and they are magic in sand, but then again never pulled a 17 foot van and probably never will!
FollowupID: 459108
Follow Up By: markcas - Friday, Oct 20, 2006 at 21:36
Ive just found out 265 75 16 Illegal to fit on my NP Pajero, Cooper dealer said they they were with in limits .??
FollowupID: 459123
Follow Up By: Member - Norm C (QLD) - Friday, Oct 20, 2006 at 21:51
Mark, this link will give you a ready reckoner for tyre size conversion.
" target="EOF" class="lbg">www.miata.net/garage/tirecalc.html
AFAIK, the legal limit is 15 mm increase over standard size. I broke that rule a little with my new tyres, but nowhere near as much as some. It is a risk, but IMO, a small one as long as you don't go too far. The real risk is not with the law, but your insurance company. If you have an accident they could technically void your cover if your vehicle is not 'roadworthy'.
As far as sand is concerned, I suspect D Jack is right. But I reckon tyre pressure and driving technique are far more important in sand than tyre type. I've been to Fraser with both the ATRs and the STs towing a 1500KG fully loaded trailer. No real problem with either. Get your tyre pressure right and maintain momentum in the soft stuff. But of course my CT is very different to a 17 foot van.
If you want no road noise with the windows up, get the ATRs, not the STs. You will need the radio up prett load to not hear the STs on some bitumen.
It is all a compromise unfortunately. No tyre is likely to do everything you want.
FollowupID: 459127
Follow Up By: Member - Andrew W (SA) - Friday, Oct 20, 2006 at 22:12
Your Cooper dealer may well be correct yet.
There are new National standards in the process of implementation which I think take the allowed difference up to 50mm.
Some states are operating under them already. Better to check it out with your appropriate qld gov agency of course.
FollowupID: 459133
Reply By: Member - Andrew W (SA) - Friday, Oct 20, 2006 at 21:35
I'd be going the ATRs from what you are saying.
If you can buy them in a capital city you are likely to get a longer warranty on them than the STs too (make sure you ask your dealer or speak with the 1300 COOPER telephone people).
That said, all tyres get louder as they get older.
I've had a set of ATs (previous model to ATRs) which were great to 82K's but now have STTs because of the High Country, Desert and Nullabor work I do. Have done 20 on them.
Andrew.
AnswerID: 200110
Follow Up By: Scubaroo - Saturday, Oct 21, 2006 at 00:25
"That said, all tyres get louder as they get older."
Really? I would have assumed that they get quieter, as the tread wears down and they approach HT in appearance! Haven't worn a new set out yet to know the difference.
FollowupID: 459150
Reply By: markcas - Saturday, Oct 21, 2006 at 06:53
Thanks to all
What Ive found out is BFG are the only ones that make a LT Tyre in 265-70-16 .Others make P construction what i need to know now is should i go with LT or stick with P con
Thanks Mark
AnswerID: 200150
Follow Up By: Member - Norm C (QLD) - Saturday, Oct 21, 2006 at 08:04
Mark, I'm not sure about LT construction, but 265-70-16 ATRs come in a 112 load rating, which is higher than most 4Bs run.
The other alternative in the ATRs is a 245-75-16. Although a bit (20mm) narrower, the diameter is almost identical to the 265-70. The 245-75-16 is available in LT.
In the STs, the 265-70-16 (P) also has a 112 load rating.
By my calculation 265-70-16 is 30.6 inches x 10.6.
If you make a small change to 31 x 10.5 you would be buying one of the most common 4WD sizes in Australia, so may have a bigger range available. This is the size STs I run and they are LTs, but only have a 109 load rating.
I'm not claiming any particular expertise, but I did a lot of research when I was in your situation and selecting tyres.
FollowupID: 459159
