Tying fridge to fridge slide
Submitted: Saturday, Oct 21, 2006 at 00:16
ThreadID: 38679 Views:3134 Replies:14 FollowUps:4
So, what do people use to hold their fridge to their slides??
Reply By: Peter McG (Member, Melbourne) - Saturday, Oct 21, 2006 at 00:27
Just Strapz
AnswerID: 200134
Reply By: Member - JohnR (Vic)&Moses - Saturday, Oct 21, 2006 at 00:36
screws into the holes from the rubber feet
AnswerID: 200136
Reply By: Willem - Saturday, Oct 21, 2006 at 00:56
Geez Bud this is a BIG question so late at night :-P
To strap or not to strap......that is the question?
AnswerID: 200138
Reply By: Chaz - Saturday, Oct 21, 2006 at 02:14
I removed the original handles and fitted eye bolts into the handles retainer threads, then lock the fridge down with turnbuckles with hooked ends.
Needless to say the fridge has never moved and is easy enough to remove.
Chaz
AnswerID: 200141
Reply By: Member - Effie C (ACT) - Saturday, Oct 21, 2006 at 03:54
Engel have a hold down kit which is four turnbuckles and four adaptors which locate under the carry handles, once fitted the fridge goes no where the fridge slide dosen't go.
Live One Day at a Time for Tomorrow May Never Come.
AnswerID: 200143
Reply By: Member - Uncle (NSW) - Saturday, Oct 21, 2006 at 05:39
We did the same as Chaz suggested there with ours Truckster, those cheap durable turnbuckles. Ours wouldnt quite reach so just grabbed a couple of those small karabiners as well and its all good and solid.Cheers mate unc.
AnswerID: 200146
Reply By: Old Scalyback & denny - Saturday, Oct 21, 2006 at 06:43
goodday mate
yuo cant sleep????
missus gone to work and i am up early
will ring later today
steve
AnswerID: 200148
Reply By: Member - Brian (Gold Coast) - Saturday, Oct 21, 2006 at 07:38
Bruce.....
we got some straps from our local camping place, they're rated at heaps of kgs, and to date have never been a problem. Cost, like, $4 each.... we use four, one on each of the Trailblaza's handles and I built 4 of those recessed handle dooveries onto the fridge slide.
Brian
AnswerID: 200153
Reply By: Old Scalyback & denny - Saturday, Oct 21, 2006 at 08:53
goodday bruce
waeco book depending on size $275 or $375 for big slides
zinc phosphated steel frame/tray
powder coated waeco gray
slide mech zinc plated steel
includes tie down straps
locks in open and closed positions
100kg load capacity (at full extension)
fridge shop at
1/97 lewis rd wantirna vic
hrs 9-4 mon friday (only know cause i rang them)
people seemed knowlegdeable and helpful
steve
AnswerID: 200169
Reply By: Member - Bradley- Saturday, Oct 21, 2006 at 08:57
I prefer shoelaces , many types available nowdays.............
AnswerID: 200170
Follow Up By: Trevor R (QLD) - Saturday, Oct 21, 2006 at 17:04
HAHAHAHA,
I was scrolling down the answers hoping no one had suggested this so I could be the funny one, but alas, I was beaten to the punch again!!!
Trevor.
FollowupID: 459264
Follow Up By: Member - Bradley- Monday, Oct 23, 2006 at 00:00
Gota be fast Trev :-))
FollowupID: 459499
Reply By: Darian (SA) - Saturday, Oct 21, 2006 at 09:27
Got a seat belt kit for nix from a bloke I know at the wreckers - they chuck heaps of them out - dismantled the fridge (Waeco 60) handles and put them through the end loops of the belts - handles back on - threaded belt under the slide tray - I rely on the tray to hold the fridge - arranged the belts so that the clasp is in front of the fridge - pull it tight for travel - unclip if needing to take the fridge out - otherwise belts slide with the fridge.
AnswerID: 200173
Reply By: awill4x4 - Saturday, Oct 21, 2006 at 14:32
I do the same as JohnR Bruce and screw upwards through the rubber feet. If you just use straps to hold it down it's pretty easy to steal as you just undo the straps but I replaced the screws (phillips head) on my Engel with Unbrako type set screws which unless you have an Unbrako tool you're not going to get it off the fridge slide.
Regards Andrew.
AnswerID: 200211
Follow Up By: Truckster (Vic) - Monday, Oct 23, 2006 at 10:17
u have screws and the tool :)??
FollowupID: 459541
Reply By: Alloy c/t - Saturday, Oct 21, 2006 at 17:57
Turn buckles , 4x , cargo barrier or not ,you dont want the fridge to move at all ,specially if you have young Cam sitting in the seat directly in front of the fridge.
AnswerID: 200235
Reply By: Shaker - Saturday, Oct 21, 2006 at 18:13
I use Engel transit lock, supposedly crash tested & ADR approved, but for extreme off road I also use rope ratchet tiedowns as a back up, just to be 101% sure!
AnswerID: 200237
Follow Up By: Johnny boy - Sunday, Oct 22, 2006 at 20:08
Yep I agree I bolted the transet lock to my fridge slide and have been offroad with no probs , we use it every single weekend when we go racing and its fast to load at 5 am when ya brain just dont want to work !!
Regards J,B.
FollowupID: 459445
