80 Series Torque Curve
Submitted: Saturday, Oct 21, 2006 at 17:59
alexk
Hi Guys,
So, after reading some posts earlier today discussing gear shifting and torque curves I decided I wanted to know the torque curve (and power) of my '96 model 80 series, petrol. I jumped onto Google and have now been fustrated for about an hour and 1/2 bottle of red less. I haven't found a thing!!
If anyone knows of a site or just the facts i'm after I'll be able to enjoy the other 1/2.
Alex
Reply By: Dave198 - Saturday, Oct 21, 2006 at 19:42
G'day Alex, try this site here.
Site Link
Torque 387 Nm @ 3600 rpm
Power 165 Kw @ 4600 rpm \
now you can have the other half!!!!!!!!!!
200250
Follow Up By: Trevor R (QLD) - Sunday, Oct 22, 2006 at 08:56
Hi Dave and Alex,
I think you will find this graph is NOT at the rear
wheels. The graph I put up earlier is at the rear
wheels of my GU. You will lose something like 30-40% of this in your drive train. So the peak power figure would be closer to 110-120KW at the rear
wheels of this car (approx obviously). similar loss in torque as
I don't know why there is not one standard graph comparing "car A" to "car B" for all makes. It drives me crazy.
Trevor.
459353
Reply By: Member - Shane D (QLD) - Saturday, Oct 21, 2006 at 19:55
Hi Alex
Have some info that may of use
4.5litre 1fz te 6 cyl
power 165 KW @ 4600 rpm
torque 387 NM @ 3600 rpm
These figures are for 100 series cruiser but I think you will find that they are applicable for 80 series as
well
as comparison
4.7 litre 2uz fe V8
power 170 KW @ 4800 rpm
torque 410 NM @ 3400 rpm
If you are overtaking/accelerating you should be working towards peak power
If you are towing up
hill you shuold be working towards peak torque,
200252
Reply By: alexk - Sunday, Oct 22, 2006 at 09:11
Thanks for your replies guys. Interesting stuff. Don't worry the other half didn't go to waist.
Alex
200309
Reply By: Member - DOZER- Sunday, Oct 22, 2006 at 16:09
Alex
3200 rpm is max torque, so also max motor efficiency...problem is, this is usually way too high revs for a 4.5, as they have a flat torque curve, that has over 300nm at 1500 rpm.......so i missed the discussion b4 about changing gears, have heard all sorts of driving in a 4.5 will return thesame fuel economy because the motor is always driven outside of its maximum efficiency revs, but if you drive it there, it uses thesame anyway...having owned a auto 4.5, it used to go best in power mode, when the box would hold onto gears longer,. and change down straight into 3200rpm (350nm) in the next gear...
200342
Follow Up By: Trevor R (QLD) - Sunday, Oct 22, 2006 at 20:42
Changing gear thread was 38666 if you are keen or bored.
Trevor.
459456
