Waeco CA-35, is it a real fridge ?
Submitted: Saturday, Oct 21, 2006 at 21:18
ThreadID: 38704 Views:23244 Replies:5 FollowUps:7
I am interested on buying a Waeco CA-35, but not sure if it is a real fridge with a compressor or is one of those warmer/coolers. It is advertised as a fridge.
Any info will be appreciated.
Reply By: Shaker - Saturday, Oct 21, 2006 at 21:26
You could have answered your own question by clicking on the Waeco link created in your own post & then navigating to here Site Link
It has no compressor, it is a 3 way, gas/12v/240v, absorbtion style fridge like a Companion.
AnswerID: 200271
Follow Up By: Member No 1- Saturday, Oct 21, 2006 at 21:40
well its got me fooked why its listed under the Kompressor page
FollowupID: 459292
Follow Up By: Shaker - Saturday, Oct 21, 2006 at 22:00
he he, me too ... but it still only took 30 seconds to find out!
FollowupID: 459299
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Oct 21, 2006 at 21:50
Hi Pelesino
Best to stick to a 40L Engel or Evakool 50L in that size range.
The Waeco CA-35
CA-35 three-way absorption cooler
Boundless independence for all outdoor enthusiasts! This low-priced absorption cooler accepts gas as well as alternating current from the power socket or direct current from the 12-volt cigarette lighter. The cooling capacity can be regulated up to a maximum level of 25°C below ambient.
.... is not a true fridge.
Good for some applications but will not perform as well as a compressor fridge.
Regards Derek.
AnswerID: 200275
Reply By: Mike Harding - Saturday, Oct 21, 2006 at 22:02
It would seem the CA-35 is a 3 way fridge:
" target="EOF" class="lbg">www.waeco.com.au/news.asp?id=149
which means it will operate from; gas, 12V DC and 240V AC
NB. My understanding is that it does not come with a gas regulator or hose so add $50 to the price.
I have owned an absorption fridge (CA-35 type – Finch) for a few years and find it suits my needs well. It will not freeze (normally) and takes some time to reduce the temp when you put a lot of warm stuff into them - 6 pack, wine cask etc. expect 12 hours to pull the temp down. However they will run for a long time from a gas cylinder - maybe 2 weeks from a 4kg cylinder? They _MUST_ be level to operate efficiently (buy a spirit level from the $2 shop) but if you camp in one spot for a week or more are hard to beat. They do not perform well on 12V and should only be operated in this mode for short periods (a few hours and make sure the engine is running as they use about 6A+) .
Horses for courses: if you're on the move each day or two buy a compressor fridge, if you stay put for three days or more an absorption fridge is hard to beat.
Mike Harding
AnswerID: 200279
Reply By: Randall_S - Saturday, Oct 21, 2006 at 22:29
I am also interested in buying a fridge / freezer and was considering the Waeco 60 litre. What are the pros and cons (other than price) compared to say, an Engel? Our main use will be for camping where we will travel to a camp site and stay for a few days, max probably ten.
AnswerID: 200282
Follow Up By: Mike Harding - Sunday, Oct 22, 2006 at 07:22
The Engels are no good at all, something like 80% of them have to be returned for warranty work whereas Waeco have consistently had a return rate below 75%. On the other hand Engels will, reliably, maintain a temperature down to +8C whereas a Waeco will be hard pressed to reach +12C. Then again the Waeco has better power consumption drawing only 9 amps against the Engel's 14 amps.
My preference is for an F&P E522B, it’s a little larger, true, but it does suit my needs well and… well… you do get what you pay for….
Site Link
Perhaps a search of the forum would reveal other information?
Mike Harding
FollowupID: 459342
Follow Up By: Member No 1- Sunday, Oct 22, 2006 at 08:55
but thats too big Mike...he wanted around 60 litres.....not 519...and as for the rest of the info....you do exagerate a little......
FollowupID: 459352
Follow Up By: Bonz (Vic) - Sunday, Oct 22, 2006 at 09:56
The engels are fine IMHO
FollowupID: 459363
Follow Up By: Pajman Pete (SA) - Monday, Oct 23, 2006 at 07:37
Mike!
I am amazed that the fish aren't biting today. Do you use expanding bait like that in rivers as well?
Pete
FollowupID: 459517
Reply By: bruce - Sunday, Oct 22, 2006 at 09:49
The Engel 60l is a good fridge...but try lifting it when full...or for that matter empty....damn heavy compared to a Waeco , which is also a good fridge...had the Engel , now have a 50l Waeco....much, much easier to move around...cheers
AnswerID: 200315
Follow Up By: Bonz (Vic) - Sunday, Oct 22, 2006 at 09:59
try lifting any fridge above 50l when full its the thing of legends.... and hemorrhoids
FollowupID: 459364
