Brakes
Submitted: Saturday, Oct 21, 2006 at 21:45
squaredeal
Looking at entering the world of camper trailers While i may keep close to the bitumen i will probably buy an off road trailer but wood like some thoughts on brakes Should i go for brakes even if total weight will be below 750kg?
Reply By: Member - Roachie (SA) - Saturday, Oct 21, 2006 at 21:50
Probably be largely dependant upon what your tow vehicle is. EG: A Ford 250 towing a piddly 750kg trailer would not need brakes fitted. However, if you drive a RAV4 or similar, then it would be good idea to a have brakes fitted.
200276
Follow Up By: squaredeal - Saturday, Oct 21, 2006 at 21:53
the present vehicle is a falcon
sedan may upgrade later
459297
Follow Up By: Member - Roachie (SA) - Saturday, Oct 21, 2006 at 22:05
Then I would have to say that brakes would be a good idea. You should be guided by what the law says, they (the law makers), would be unlikely to allow you to drive on the roads with an unsafe set-up. The thing to watch though is that a trailer which is "just" under the limit to require brakes, very quickly gets weighed-down with gear you add, making it over the limit.
459301
Reply By: Bilbo - Saturday, Oct 21, 2006 at 23:33
I'd say go with brakes. Whilst there won't be too many with electric brakes, I'd say try and get a camper with electric brakes and get yer car fitted with Tekonsha Prodigy brake controller. Flamin' marvellous device.
As Roachie sez, it doesn't take much to push 'em up towards a tonne.
Bilbo
200287
Reply By: Member - Bucky (VIC) - Sunday, Oct 22, 2006 at 04:50
Electric breaks are the go,, you pay for them, but in the big picture,,
When you ever have to apply them firm / hard, ( and you will ) its good to know that there is nothing that will will be pushing you.
Its the only way to go !
Bucky
200295
Follow Up By: squaredeal - Sunday, Oct 22, 2006 at 08:37
Thanks fellows, confirmed what i thought
" Poor man pays twice"
Cheers to all
459347
Reply By: Batboy - Sunday, Oct 22, 2006 at 09:41
Get the brakes. Our trailer is towed by a GU patrol and a has always had brakes.
The trailer may be just over the 750kg mark, reasonably loaded.
Last weekend we did a trip and for some reason the brake light fuse blew disabling the trailer brakes. The difference is very noticable even with a large vehicle towing a fairly small trailer. Go the brakes if you can, although I expect you will be looking at nearly $1000.00 including brakes, controller and controller fitting.
Shop around for the controller. We use a prodigy and got it nearly 1/2 price off the web somewhere and is relatively easy to fit yourself
Jim
200312
Reply By: Kumunara (NT) - Sunday, Oct 22, 2006 at 16:53
I would go for brakes
I bought my camper trailer used and it wasn't fitted with brakes.
I have towed borrowed trailers with brakes.
The difference is noticeable.
200347
Reply By: D-Jack - Tuesday, Oct 24, 2006 at 10:25
Gone from a Cavalier camper, probably less than 750 kgs loaded, no brakes, still takes longer for the Jackaroo to pull up than without, and the Jackaroos ahve got very good brakes.
Now have a very similar setup (not a Cavalier though) WITH electric brakes, haven't had to stomp on the brakes yet but I fell confident that they would stop me almost as quick, if not quicker than the vehicle when it wasn't towing.
Good investment in both resale and safety I say. Also, wet slippery dirt roads, or loose gravel, (you may do these in the Falcon or may upgrade to a 4wd one day) you can set the brakes so they come on harder and earlier than the vehicle brakes, effectively helping straighten up the trailer if it gets out of shape a bit.
D-Jack
200648
