GU Patrol shudder
Submitted: Tuesday, Oct 24, 2006 at 20:48
ThreadID: 38794 Views:2310 Replies:4 FollowUps:3
Started to notice a slight shudder in 2000 3.0 ltr when auto changes up into overdrive. 140 000 km on clock
Not used for towing but I am concerned that this may be a sign of things to come.
Reply By: shaen - Tuesday, Oct 24, 2006 at 21:37
Mate had one.
Give it up & buy a 4.2
AnswerID: 200773
Follow Up By: Brew69(SA) - Tuesday, Oct 24, 2006 at 21:40
I think he may have been after some more constructive comments. :)
FollowupID: 459897
Follow Up By: PatrolBen - Tuesday, Oct 24, 2006 at 22:12
Probably.......
But it is the best advice he can recieve LOL
FollowupID: 459903
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Tuesday, Oct 24, 2006 at 22:17
The auto sometimes suffers from this due to tailshaft balance
being out...forget the naysayers, check tailshaft balance.
AnswerID: 200780
Reply By: banshee1 - Tuesday, Oct 24, 2006 at 23:05
cheers for the response, I will have a look at the prop shaft, although I would have expected a problem like that to occur at all speeds!
AnswerID: 200790
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Wednesday, Oct 25, 2006 at 06:29
Often it is a harmonics thing. If it is a minor bealance problem, you may only notice it at a particular speed.
FollowupID: 459946
Reply By: pedro the swift - Wednesday, Oct 25, 2006 at 10:56
I suggest you think about the auto converter lockup clutch. Check to see if the engine revs change up and down in synch with the "shudder". I had a similar happening in my auto patrol.
Not a "shudder" but intermittent "slipping" of converter lockup when in overdrive. revs changed as it happened. Started round the 200,00km mark.
Had autobox rebuilt. No further problem to date.
AnswerID: 200837
