Ethanol
Submitted: Wednesday, Oct 25, 2006 at 20:48
Barnesy
There is a lot of rubbish that has been fed to us about ethanol damaging engines. But I don't really know what to believe about it.
My missus has a 92 EB Falcon straight 6 with 425 000 km on the clock. Would an ethanol blend unleaded be suitable? If yes what percentage would be advisable?
Will it make the engine perform any differently?
Are there any precautions or modifications I should do?
I'm using 100% biodiesel in my GQ and love it so have no qualms about using renewable fuels.
Any advice or experience appreciated.
Barnesy
Reply By: Ozboc - Wednesday, Oct 25, 2006 at 21:07
HI there - are you making your own bio diesel or are you buying it ?
I have just started to make it and have just added 30 litres to 1/2
tank of dino diesel in my nissan st 4.2 litre turbo -- i have noticed a power loss- but will expect this to improve soon .
Boc
200951
Follow Up By: Member - Andrew W (SA) - Thursday, Oct 26, 2006 at 18:30
the power loss may be from the fuel filter starting to clog up on the built up residues that the Biodiesel is flushing out of your fuel system.
Common, and only real issue with running BioD - after the first few tanks your filter will need replacing.
Andrew.
460275
Follow Up By: Barnesy - Monday, Oct 30, 2006 at 00:08
Boc, I am buying the stuff from SAFF in South Oz. I am starting to look into making my own once I'm satisfied i can produce good quality stuff. SAFF in
Adelaide have all but run out of 100%, they can't source it, maybe because of the poor crop yeilds across the country.
What processes are you using to make it Boc, what modifications to your car have you made and where do you source the raw materials from?
Barnesy
461104
Follow Up By: Member - Andrew W (SA) - Monday, Oct 30, 2006 at 08:00
um "all but run out" - now who told you that?
461121
Reply By: howesy - Wednesday, Oct 25, 2006 at 21:07
Ethanol by itself is highly corrosive which holden found out quickly when they exported commodores to ethanol countries and had to change all the fuel lines in export vehicles.
Overseas they run much higher levels (40% and up)
We are told that at a 10% mix it will not affect fuel lines or engine longevity.
You do what ever your heart tells you. Probably wont do anything and if it did would take so long at a 10% level that you will probably have got rid of the car by then.
me myself , i look at it this way. If i took some battery acid and poured it into a glass at what I said was an exceptable level that wont hurt you would you drink 8 litres of it a day??
just my opinion and opinions do vary. :-)
200952
Reply By: Kiwi Kia - Thursday, Oct 26, 2006 at 06:40
Ethanol can damage some big end bearings and some types of plastic/rubber/neoprene hose, o-rings etc. Don't know what % is required to do this but there is
well documented evidence as to why you should not use it if the vehicle has not been built to take it.
200969
Follow Up By: Member No 1- Thursday, Oct 26, 2006 at 07:34
how does ethanol damage big ends
460158
Follow Up By: Ray Bates - Thursday, Oct 26, 2006 at 07:50
What are you doing with fuel in the sump????
460159
Follow Up By: Member No 1- Thursday, Oct 26, 2006 at 08:11
I think he thinks he explained this below....but i still have no idea on how ethanol can damage bigends, unless he is trying to tell us its in the sump as you say Ray....at which point i go along with you..... Why would you put ethanol in the sump?
460161
Follow Up By: Kiwi Kia - Thursday, Oct 26, 2006 at 08:31
You always get some fuel products ending up in the sump. Thats how your diesel soot makes your sump oil look so dirty. Its not very much but it does happen and it does effect the oil which in turn also contacts gaskets, o-rings in oil pumps etc. etc..
460167
Follow Up By: Member - andrew B (Kununurra) - Thursday, Oct 26, 2006 at 12:28
Gday
Didn't think ethanol would last too long in a sump, it boils at about 80 degrees from memory
Cheers Andrew
PS - not too long ago both Holden and Ford said no to ethanol intheir cars. About the time fuel prices went up dramatically the cars were all of a sudden ok on 10% mix......with no modifications........6cyl car sales were dropping around the time of the announcement that it was now OK......bit convenient!
460199
Reply By: Kiwi Kia - Thursday, Oct 26, 2006 at 07:48
The 'soft' metal is attacked by methanol, it looks like little worm tracks on the surface leaving eroded patches. This can be avoided by using a differnt chemistry for the big end wearing surface material. The big ends as used in some south american manufactured vehicles have taken care of this for many years.
200977
Follow Up By: obee - Thursday, Oct 26, 2006 at 09:26
was a time when a diesal driven vehicle had to have oil removed regularly from the sump because unburnt fuel would be forced past the rings. One of the reasons we change oil is because of contamination from the firing chamber.
Engineering these days is so good but keeping all that compression from leaking past the rings is a hard ask.
Owen
460173
Reply By: MAVERICK(WA) - Thursday, Oct 26, 2006 at 09:23
the use of ethanol is a political sop to growers who through outdated farming practices are unable to remain profitable..............you need to use more to get the same bang in the cylinder - it is corrosive (as above) and does nothing for any environmental concerns...........at the supposed discount offered at the pump you are wasting your money and will end up spending on repairs and/or a new engine. rgds
200989
Follow Up By: 666toy - Friday, Oct 27, 2006 at 20:21
JUST A LITTLE THOUGHT ,
the modle t ford was desighned to run on alcohol fuel with no side effects.
i ran a 95 5.0 fairlane on raw alc fuel with out any mods except fuel filter just to see if it could be done & guess what ...25,000klm no ill effects actually ran cooler & oil stayed cleaner . when i tore the eng down for inspection no internal damage . so go figure ....(i think the oil companys are brainwashing you folk) .ethanol fuel is a great fuel ..dont be afraid to use it...
460595
Reply By: Robin - Thursday, Oct 26, 2006 at 13:47
I think a 92 EB would be in the realm of possible damage but beyond that I see no way to benefit from Ethanol currently.
Its no cheaper considering the loss of range even as E10. To go further you would need a cheap soucre of the stuff and unlike bio-diesel this doesn't seem on the horizon for a while.
Unlike gas which has a lot going for it in that car.
Robin Miller
201039
Reply By: flappa - Thursday, Oct 26, 2006 at 13:57
Why would you use Ethanol ?
Its most often dearer the unleaded , has less range , and supposedly less power.
Why on earth would you pay more for something with reduced benefits and "potential" damage ?
201042
Follow Up By: Member - Davoe (Nullagine) - Thursday, Oct 26, 2006 at 14:48
The argument it is green is untrue also what the hell is green about habitat
clearing replaced by monoculture?? that is right up there with anything with the destrction of native flara and fauna
460227
Reply By: Kiwi Kia - Thursday, Oct 26, 2006 at 16:15
In some countries alcohol is a cheap by-product of other industries. eg milk powder, sugar cane etc. In South America alcohol products are commonly used as fuel extenders. The burnt products from alcohol is almost entirely water so it does have some green effect.
After you have taken almost all of the solids out of milk to make milk powder the left over contains lactose (milk sugar) which is then converted into alcohol and could be used as motor fuel extender. In fact I would take a guess that a large proportion of the vodka that you buy over the counter locally is made from imported essence flavour mixed with locally produced alcohol where the alcohol comes from milk as described above.
201065
Reply By: Ianw - Thursday, Oct 26, 2006 at 19:05
g sus,
If ethanol does that to metal bearings I'm gonna have to stop drinking the stuff
201088
Follow Up By: Ozboc - Friday, Oct 27, 2006 at 17:00
Just stop eating those car parts and you should be ok ;)
Boc
460540
