Trojan Batteries
Submitted: Thursday, Oct 26, 2006 at 10:38
ThreadID: 38835 Views:2416 Replies:2 FollowUps:2
Hi. I have a Trojan 27tmh battery as an auxillery in my caravan (don't say I should have an AGM as I cannot afford one at present).
My question is what voltage should this battery have when fully or near fully charged?
Secondly what is the maximum amperage will this battery accept?
Thank you
Reply By: Member - Craig D (SA) - Thursday, Oct 26, 2006 at 10:46
Nonimal voltage = 12V
Absorption Voltage = 14.4 - 14.8
Float = 13.5
Equalise = 13.5
Max Current C20 divide 5 (Amps)
AnswerID: 201005
Follow Up By: Ray Bates - Thursday, Oct 26, 2006 at 11:15
Thank You
FollowupID: 460191
Reply By: Markymark - Thursday, Oct 26, 2006 at 11:24
All batteries I have bought always seem to sit around 12.6 volts off the shelf.
Mark.
AnswerID: 201014
Follow Up By: V8 Troopie - Thursday, Oct 26, 2006 at 23:53
I second that. What was quoted above are charging voltages which are quite different to what a fully charged battery reads at the terminals after it has been OFF the charger for 24 hours or so.
That "nominal" voltage bit is a furphy, if a 12V battery actually reads 12V at rest then its pretty empty.
The original poster is well advised to use a hydrometer (glass tube/ bulb thingie) to test the charge of each cell in the trojans, the ones I had on my boat did not last very long.
Klaus
FollowupID: 460344
