batt drain
Submitted: Thursday, Oct 26, 2006 at 20:17
4wdnut
advice needed please, i have dual batt, most acc and amp wired to aux agm batt, no load on batt for 2 days, measured volts 12.51 15 hours later it was12.47 volts is this normal, i think it could be amp thats direct to batt and neg to a bolt from cargo barrier which has aluminum angle connected to support roof space storage, the sparky said aluminum is a good earth point as the bolt went toroof metal. thanks.
Reply By: Mike Harding - Thursday, Oct 26, 2006 at 20:23
Your post is not clear but after charging any lead acid battery (an AGM is an LA battery) it is quite normal to see a drop in terminal voltage and 12.47 volts is reasonable - frankly, unless you have a quality multimeter, I would not expect it to be accurate to 0.3% anyway - I suspect you have no cause for concern.
Mike Harding
201100
Follow Up By: Member - 'Lucy' - Friday, Oct 27, 2006 at 00:13
Could you please elucidate as to what you identified as being 'not clear'
460347
Follow Up By: Mike Harding - Friday, Oct 27, 2006 at 08:21
I would... but it's not really very clear.... :)
460377
Follow Up By: Member - 'Lucy' - Friday, Oct 27, 2006 at 10:54
I am with you on this one - just thought it was me
460430
Reply By: Derek from Affordable Batteries & Radiators - Thursday, Oct 26, 2006 at 20:23
Hi 4wnnut
0.04 Volts is not a drop over 15 hours !
Put an amp meter on it if you like but sounds fine to me.
Don't worry about it.
201101
Follow Up By: HJ60-2H - Friday, Oct 27, 2006 at 09:04
Batteries have an internal resistance and this will see them very slowly discharge over time. The drop you have recoreded is nothing and as others have suggested probably inside the error range of your voltmeter.
I'd be quite happy that everything is OK if this was my system
460395
Reply By: 4wdnut - Friday, Oct 27, 2006 at 18:29
thanks, the drop was consitent over 2days with 0.04 every13-15 hours ,sorry post was a bit confusing, too much information.
201288
