Radtel
Submitted: Friday, Oct 27, 2006 at 10:02
ThreadID: 38867 Views:3547 Replies:5 FollowUps:4
Radtel Network is about to commence a major reshuffle of frequencies and channel numbering allocations.
Site Link
Reply By: Disco123 - Friday, Oct 27, 2006 at 20:58
Yep got my notification in the mail today.
Footloose ( or Wayne or Signman) I need your help again. It seems from their letter Radtel are offering a reprogrammed Eprom for the Codan 8528 for $27.50 plus p+p. Sounds like a good deal. Is this just an easy plug 'n' play type fit? i.e. can a novice just replace the existing card or is there something more sinister involved?
Also how do you get a printout of the new Eprom's channels?
AnswerID: 201321
Reply By: HJ60-2H - Friday, Oct 27, 2006 at 21:03
I am lucky, I have the programming S/W for the Barrett 550 so can do it myself, easy
AnswerID: 201323
Follow Up By: Mike Harding - Friday, Oct 27, 2006 at 21:29
Emmmm...
Some naughty people might consider making such software available to others who have spent a lot of cash on radios they now find will not do what they want...?
Mike Harding
FollowupID: 460609
Follow Up By: HJ60-2H - Friday, Oct 27, 2006 at 22:58
You need a PC that can run a DOS application and a serial port which you can get to with in 10M of the powered up and usable radio. Laptop is best I found. A null modem cable connects the radio to the PC's serial port.
You then download the current frequency set up from the 550 radio, edit the RADTEL frequencies and upload the new set up back to the radio.
So as well as the S/W you need PC, DOS editing ability, upload/download instructions for the radio and null modem cable.
S/W I have is ONLY for the 550. For 950 I believe you need 950 specific S/W.
Given the number of channels the 550 has I found that the S/W etc enabled me to program a heap of extra (most I set up as Rx only) frequencies such as the VMC and VMW weather stations, marine warnings, ABC short wave etc. I also have some HAM frequencies in it for amateur use plus a couple of manually programmable channels that I can set up off the control head on the fly again for HAM use.
If anyone with a 550 feels confident to play with all of this on their own (& accept the consequences) let me know. For most the $27.50 option that Doug at RADTEL is offering is the best option.
Only a couple of the RADTEL frequnecies are changing so you may still get by with the existing set up you have. But I will be changing mine.
FollowupID: 460637
Reply By: Richard Kovac - Friday, Oct 27, 2006 at 21:17
Thanks Gmouse
We will look into it hope we only have to change the radio not the tap
Richard
AnswerID: 201326
Reply By: markeaust - Friday, Oct 27, 2006 at 23:48
Disco123,
You would need to confirm with them, but they should send you a printout of the channel setup with the EPROM. For the record, $27.50 is very cheap for doing a re-programming job on these things. I would imagine that they have made up a 'template' that includes VKS737, Radtel, RFDS and a few listening frequencies and would likely charge additional if you wanted any departure from the standard 'travellers pack'....ie any ham channels or other listening channels etc...
Reprogramming these 8528's is simply a matter of removing the EPROM, using the Codan specific software to re-write the channel plan (which in itself is a steep learning curve), mucking around with the file extensions, depending upon the type of EPROM programmer you have, then burning the file to the EPROM. Replace EPROM in radio..... easy...all for $27.50. They wouldn't be making anything $$-wise from it , but it is in their interests to keep people on their channels, I guess. For those who don't do it all the time, it takes many hours of experimentation to get it all going to plan.
The computer programmable sets, like the Codan 9323, NGT, Icom 7000 and the Barrett 550/950/2020 are a little easier....write channels in software program, plug set into computer via programming cable and program.....easy, but you need to send the radio somewhere to have it done and postage/insurance isn't cheap.
My advice would be to find your nearest dealer or friendly radio tech with access to the right equipment and let them do it for you. You will need to work out the cost differences between pack and post to Radtel and using someone closer to do it on the spot for you.
In relation to tapped whips, the frequency changes, as far as I can see are at the higher end of the frequency spectrum. The changes at 16mHz SHOULD be OK depending upon exactly where your tap is tuned to currently. The tap that covers 11450 kHz will also cover 11487kHz but will be nearly 400kHz out for what seems to be a new frequency at 11013kHz out and may not be so good. Ahhh the advantages of autotunes...!
Hope this helps clarify. If I can be of more assistance to members...let me know.
Mark
AnswerID: 201370
Follow Up By: Disco123 - Saturday, Oct 28, 2006 at 14:23
Thanks Markeaust. I'll have a chat with some local techs.
Radtel have quoted low prices to offset the inconvenience of their changes, but as the changes are to imrove their services and accessability of clear channels I'm all for it.
FollowupID: 460721
Reply By: huntin - Friday, Nov 03, 2006 at 09:13
Seems unfair that I should pay for radtels coverage problems. I wont be renewing membership.
AnswerID: 202762
Follow Up By: markeaust - Saturday, Nov 04, 2006 at 22:34
Huntin,
It's not simply a matter of their coverage problems. HF frequencies are used all over the world and can travel vast distances across the globe. It appears that a couple of their frequencies have been problematic, most likely from overseas interference.
I personally applaud the organisation for tackling the problem and not just ignoring it. It would have involved much negotiation with the ACMA to get them to recognise the problem and finally allocate other frequencies.
In my experience (over 20 years) of using HF, many organisations have had interference problems similar to this....RFDS, Commercial HF users, Telstra Radphone (when they were available). Rarely was anything ever done about it. The cost of changing frequencies is really a small price to pay for clearer communications when you really need it in remote areas.
Mark
FollowupID: 462654
