Air Flow Sensor Cleaning?
Submitted: Friday, Oct 27, 2006 at 14:56
ThreadID: 38877 Views:9345 Replies:8 FollowUps:6
What is the best way to clean the air flow sensor?
I believe carburettor cleaner does the job, but how do you use it, do you just spray it on & let it dry, or do you flush it off with water?
I see in the US, CRC have a dedicated product for the purpose Site Link
Reply By: prado4x4 - Friday, Oct 27, 2006 at 15:04
Spray it on and let it dry.
You should see the brown gunge dissapear and a silver wire become visible.
Don't touch the hotwire element at all. They are very fragile, and if the wire breaks, its an expensive replacement.
AnswerID: 201250
Reply By: cam_champion - Friday, Oct 27, 2006 at 15:20
just make sure it is carby cleaner you are using, not contact cleaner.
After using carby cleaner I then dry it off with some compressed air
AnswerID: 201255
Follow Up By: 3.0turbob - Friday, Oct 27, 2006 at 15:36
Why no contact cleaner ? I thought either was OK to use.
Rob
FollowupID: 460520
Follow Up By: c j - Friday, Oct 27, 2006 at 16:58
I'd like to know why too as I heard that you should use contact cleaner and not to use carby cleaner. Never had a problem using contact cleaner on mine, just takes a few sprays.
FollowupID: 460538
Follow Up By: Redeye - Friday, Oct 27, 2006 at 17:58
I used Dick Smith contact cleaner on mine and had to purchase a new one. It went from flat spots to not working instantly.
Mind you I did drown it
Redeye
FollowupID: 460559
Reply By: Sign-man - Friday, Oct 27, 2006 at 15:42
Dunk it in Metho..
AnswerID: 201263
Reply By: Muzzgit [WA] - Friday, Oct 27, 2006 at 18:16
I have tried carby cleaner with no luck, so I just went and bought a new MAFS.
Expensive? Not really.
About $240.00 and considering drama with the car not running properly and the possible damage done to the engine, it's not a huge expense.
AnswerID: 201287
Follow Up By: 3.0turbob - Saturday, Oct 28, 2006 at 12:24
I went to my local Nissan dealer recently (Western Sydney) to get a price for the MAF sensor (just for curiosity) and was quoted $980 !!!!.
So far no probs with mine... Oct 2001 model
FollowupID: 460714
Follow Up By: Muzzgit [WA] - Saturday, Oct 28, 2006 at 21:52
He quoted you that cos the cheaky plick included the ducting and pipework that it sits in as well!!!
Go back and ask how much just for the MAFS itself.
FollowupID: 460828
Reply By: jbutl - Saturday, Oct 28, 2006 at 09:58
I was the person with the original prado air flow sensor problem in this discussion. The car is fixed now. I used electronic contact cleaner and dosed it liberally. I had rung CRC direct and they told me to use CO Contact Cleaner. Dont use carby cleaner as it leaves a residue and maybe corrosive. The Mass Air Flow Sensor cleaner CRC make in the USA is not available in OZ. I will be cleaning the sensor in my car every 40,000 . Huge difference in performance.
AnswerID: 201395
Follow Up By: c j - Saturday, Oct 28, 2006 at 21:32
Someone in the US compared the contents of the CRC MAF cleaner and the contact cleaner and they were the same they reckoned. Carby cleaner is pretty aggressive stuff.
FollowupID: 460818
Reply By: Member - andrew B (Kununurra) - Sunday, Oct 29, 2006 at 11:55
Gday All
Local Nissan dealer and also ARB bloke recommended Brake Cleaner. They were both of the opinion that they are similar products, but the brake cleaner isn't as aggressive as the carby cleaner. I took their advice, and Brake cleaner worked a treat.......haven't done it for a while, might do it again next weekend. I was skeptical of the brake cleaner, but the nissan dealer would have got a visit if it didn't work or wricked it.
Cheers Andrew
AnswerID: 201548
Reply By: Shaker - Sunday, Oct 29, 2006 at 12:55
Thanks for the replies, it sure looks like the jury is still out on the correct way to go about it, which was the reason for the post.
AnswerID: 201558
Reply By: Member - Glenn D (NSW) - Monday, Oct 30, 2006 at 22:04
I clean a lot of things of this nature , but on aircraft .
We have gone from using various sprays to using Isopropyl Alcohol , cause it doesnt leave any residue .
The only problem is it doesnt dry very fast , you have to use compressed air or leave for a long time to air dry if the sensor is fragile .
Glenn.
AnswerID: 201921
