Fuel pump help ????? Nissan Patrol -
Submitted: Saturday, Oct 28, 2006 at 11:54
Ozboc
Hi there - car has need been able to get over 2 k rpms for the past few days -- replaces fuel filter and fuel lines ---
NOW i can hear the fuel pump making a knocking noise untill i hit the prime button and pressure up the system ( fully primed btw) and after a few seconds the knocking sound comes back
can anyone suggest any help ??
Boc
Reply By: Ozboc - Saturday, Oct 28, 2006 at 11:54
sorry forgot to add 99 nissan patrol 4.2 litre turbo
201414
Reply By: Member - andrew B (Kununurra) - Saturday, Oct 28, 2006 at 12:26
Gday Boc
Possibly getting a bit of air from somewhere, maybe a pinhole in the ful line. More expensive possibility is the fuel pump - could be the built in lift pump has a fault - could be worse........I'd get it checked by someone in the know...
Good luck
201416
Reply By: Member - Uncle (NSW) - Saturday, Oct 28, 2006 at 12:44
Hi ozboc, there is a 17mm bolt on the top of the fuel pump,if you take this off, be careful not to lose the washers,and inside is a small gauze filter that will block up with crap. Take it out and clean that ,then put back in ,or get a new gauze if it's totally stuffed and that could be your problem.Cheers Unc.
201418
Follow Up By: Member - Uncle (NSW) - Saturday, Oct 28, 2006 at 12:48
The part number is 14371-R8025A
460717
Follow Up By: Old Johno [NSW] - Monday, Oct 30, 2006 at 16:00
Uncle,
I've got a 2004 Intercooled Turbo.
Went looking for the filter you talk about. The only 17mm bolt I found is at the front of the pump and appears to come from the filter. Removed the 17mm Fuel bolt but there are no filters inside at all.
Question is should I have a filter there or did this model do away with them
461224
Reply By: Ozboc - Saturday, Oct 28, 2006 at 12:58
Gday guys -- the problem was the little filter under the 17 mm bolt ( for fuel line ) i would estimate it was almost 95% blocked -- cleaned it out and now she is flying again like a new car
thanks for your help :)
Boc
201420
Follow Up By: Member - Uncle (NSW) - Saturday, Oct 28, 2006 at 13:39
Great stuff, good to hear it was somrthing simple.
460719
Follow Up By: Member - andrew B (Kununurra) - Saturday, Oct 28, 2006 at 15:58
Yep, much simpler and cheaper than my initial thoughts
Cheers Andrew
460732
Reply By: honestjohn - Saturday, Oct 28, 2006 at 17:09
had the same drama once myself the little filter was the problem.the boys at northside 4*4 caboolture found and fixed it no worries.
201442
Reply By: Muzzgit [WA] - Sunday, Oct 29, 2006 at 01:40
Just goes to show that fuel filters don't stop all the crud getting through. And why isn't this simple fix mentioned in the owners manual? Or is it?
201521
Follow Up By: Ozboc - Sunday, Oct 29, 2006 at 06:58
Hi there - no mention of this little filter in the owners manual at all (
well not the version i have anyway ) another thing i was disapointed with is the fact the owners manual does not state the filter numbers for fuel or both oil filters. had to make a manual recording in the book for my own future reference
Boc
460876
