Canopy Ventilation / Pressurisation
Submitted: Saturday, Oct 28, 2006 at 15:38
ThreadID: 38905 Views:9137 Replies:6 FollowUps:0
Afternoon All,
Just wondering what you guys use to provide positive ventilation to your canopies in order to keep out dust and exhaust fumes without letting rain in. P.S not real keen on the "periscope" looking yacht vents that were pictured in the archive search.
My Staffy thanks you in advance
Cheers, Heefers
Reply By: djm67 - Saturday, Oct 28, 2006 at 16:18
My flexiglass canopy has a forward facing vent that can be opened rather than the whirly bird type, I had the option when I bought it which type I wanted.
AnswerID: 201435
Reply By: Member - Stephen M (NSW) - Saturday, Oct 28, 2006 at 16:32
I have the same as djm but will still let the dust in if Im not the one out front, I have put some extra sealing around my rear tailgate and seems to work very well, I found before most of my dust coming in was from around the gate but now very little if any gets in and thats with the vent kept shut as some times I forget to shut it and when it rains well you know the outcome, so now virtually dont use it. Regards Steve M
AnswerID: 201436
Reply By: Darian (SA) - Saturday, Oct 28, 2006 at 17:29
Yep - important air for the dogs - and you just have to keep the dust out on those long outback trips too. That's why I did my original scoop on the Bravo's canopy, using plumbing fittings - I thought the yacht vents looked quite professional (better than mine was). How about plumbing a flexible 50mm pipe under the car from thetary, to the front grill area ?
AnswerID: 201446
Reply By: Member - Vincent A M (NSW) - Saturday, Oct 28, 2006 at 17:59
Found the best thing is a hole with cover over it with the opening at the bottom, fit a 12 volt fan with a car air filter in place it will give filtered air & it will keep the canopy pressurised even when stopped should be able to make for under $100
i use a small jap car radiator Elec fan & Holden air filter with a alloy cover thru the base of the head board even works well when i have a rag canopy, helps keep the dust out & the back cooler, helps the fridge too
AnswerID: 201455
Reply By: Dave198 - Saturday, Oct 28, 2006 at 21:25
I don't own a ute , but is there a way to put a pipe or hose from the cabin into the rear?
I am thinking possibly a grommet in the floor pan somewhere and attach a hose to take air into the rear to pressurise it a bit.
Maybe a small fan to boost it through the pipe into the rear.
Most coaches that do a bit of outback work have a fan under one of the seats blowing air from the cabin into the luggage area to stop dust getting sucked in and all over the luggage.
Most of the time we travel with the a/c on and I think maybe that would provide enough air to go through to the rear.
AnswerID: 201494
Reply By: Member - Phil G (SA) - Saturday, Nov 04, 2006 at 00:55
Mines a solid aluminium canopy - if the side doors are sealed, and theres no rear door, then you won't get any dust.
If you're talking about canvas, then an opening flap at the top, front on each side works well on a friend's canopy. Need to close it when it rains, but then you won't get dust anyway!
AnswerID: 202977
