Goldstream Solar Panels
Submitted: Saturday, Oct 28, 2006 at 16:39
ThreadID: 38909 Views:4920 Replies:7 FollowUps:10
I have a Goldstream Wing III camper and i was interested to here from anyone who has installed solar panels on their van. I dont imagine it makes much difference between the different campers but the Goldstream roof seems very flexabile and lacks much in the way of rigidity. Second option is to get a panel or two and use on the ground or vehicle.
Reply By: Redeye - Saturday, Oct 28, 2006 at 18:06
Steven,
One thing to remember is that the panels must be in the sun to work. If you put the panels captive on the vehicle or the van you will not be able to park them in the shade.
Redeye
AnswerID: 201456
Reply By: Grungle - Saturday, Oct 28, 2006 at 19:05
Also fixed panels will only deliver 50% of what can be achieved by siting on the ground and moving every couple of hours. It is a very inefficient way to charge your batteries. I get 5A from a sited 80W panel and 2.7A from exactly the same panel mounted on my father-in-laws caravan roof.
David
AnswerID: 201462
Reply By: Teabag - Saturday, Oct 28, 2006 at 19:09
Redeye has a very valid point and one that isn't normally thought of. The other benefit with portable is you can use them on the vehicle when you are travelling without the camper. I have a portable set of 2 X 50 watt panels which I can plug into the Kimberley Kamper or the vehicle, works a treat.
Has Redeye stated if you have them on the roof of your camper then putting the camper in the shade will do nothing for charging the batteries........
AnswerID: 201463
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Oct 28, 2006 at 20:43
Hi Steven
Go for 100w Bi-fold.
Roof top would need twice the capacity.
Our 100W Bi-folds are more popular than fixed units.
Regards Derek.
AnswerID: 201484
Follow Up By: Member - Steven H (ACT) - Saturday, Oct 28, 2006 at 20:51
Hi Derek I am leaning toward a Bi Fold unit although maybe a little smaller 60-80W?
FollowupID: 460803
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Oct 28, 2006 at 21:10
80w will not keep up with a fridge. 100w min.
FollowupID: 460812
Follow Up By: Teabag - Sunday, Oct 29, 2006 at 10:51
There are many factors to take into account when selecting a Solar Panel set up. It isn't as easy as just buying a Solar panel and connecting it up and hoping it will maintain full charge. You need to take into account several things such as Peak Amp output of the Panel noting that this is in ideal conditions and is rarely meet, what type of battery bank you are charging, what equipment is going to be used and it's usage rate in Amp/hrs (always take worst case scenario) and a simple thing such as the amount of effective sunlight you will get for that time of the year and what sort of regulator you wish to run. Below is an example of what sort of sunlight effective hours you will get.
Location Winter Summer
Melbourne & Southern Regions 2hrs 5.5hrs
Central NSW, SA and SW W.A 3hrs 6hrs
Central Aust 4.5hrs 8hrs
Broome To FNQ 5hrs 6hrs
Note: This is only a rough guide.
So using central NSW as an example with 2 X 50watt Solar Panels (6.3Amp Max) with 3 hrs in Winter and 6hrs in Summer gives 18.9Amps for the day in Winter and 37.8 Amps in Summer. Now with a 40ltr Engel draws a reported 2.5Amp hr Max which means an Engel alone will suck 60Amps out of your Battery. Now this is a very worst case and shouldn't draw anywhere near that? So in effect you are only replacing a 1/3 of what you use in winter and just over half what you use in summer. Now this is just the fridge without lights, inverters etc but I wouldn't envisage the Engel using this amount of power especially in winter but it is better to work on worst case as you can have rainy days, overcast days etc and you honestly can't count on the panel putting out it's claimed peak Amp/hrs.....I hope this helps and if you have any further questions, feel free to ask. Has Derek has already stated I would guest 100Watt would be your min without knowing you expected load requirements. I run twin 50watt panels which have performed exceptionally well running a 40ltr Engel and my camper LED lighting.....
Thanks,
Teabag
FollowupID: 460890
Follow Up By: Member - Brian (WA) - Sunday, Oct 29, 2006 at 14:20
Hi Steven. I have my panels mounted on the roof of my 4by (2x75-1x80). Hinged
so I can tilt them if need be.I made a lead up.long enough to reach the battery on
the camper. Put a plug in wired to the battery, I just unplug from the batterys in the wagon and conneck to the camper battery for a couple of hours in the morning to
give it a bit of a charge. I run two 40lt engels ( 1freeze, 1fridge) I turn the
freezer back to no2 setting when the panels stop getting any power.
I have spent 3weeks in the bush like this. Keep thinking of a gene backup but as of
yet I have not needed one. Others may say I need more than this but it works for me. cheers Brian.
The goldstream is a good camper, like mine
FollowupID: 460933
Follow Up By: Member - Brian (WA) - Sunday, Oct 29, 2006 at 19:42
Steven
hope this works. you can see the lead from the panel to the battery box
http://i30.photobucket.com/albums/c315/brian-m/BandyaAug2006007.jpg
brian
FollowupID: 460994
Follow Up By: Member - Brian (WA) - Sunday, Oct 29, 2006 at 19:55
steven
maybe this
FollowupID: 460996
Follow Up By: Member - Brian (WA) - Sunday, Oct 29, 2006 at 20:05
Now this might work having trouble getting the piccies to function ooppppsss!!!!!!
FollowupID: 460999
Follow Up By: Member - Brian (WA) - Sunday, Oct 29, 2006 at 20:10
FollowupID: 461001
Follow Up By: Member - Brian (WA) - Sunday, Oct 29, 2006 at 20:12
this is the hyperlink to the piccies
maybe??
FollowupID: 461003
Reply By: Member - Brian (WA) - Sunday, Oct 29, 2006 at 19:59
[IMG]http://i30.photobucket.com/albums/c315/brian-m/BandyaAug2006007.jpg
AnswerID: 201620
Reply By: Member - Brian (WA) - Sunday, Oct 29, 2006 at 20:02
Hope this works
trying for the last time
maybe???
AnswerID: 201622
Follow Up By: Member - Steven H (ACT) - Sunday, Oct 29, 2006 at 20:31
Hi Brian and thanks for your efforts but unfortunatley the hyperlink dosent seem to work. A for effort and persistence ;-]
FollowupID: 461010
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Oct 29, 2006 at 21:00
AnswerID: 201650
