DUAL BATTERIES ON THE T/D 100 SERIES
Submitted: Saturday, Oct 28, 2006 at 23:13
Brooka27
I have been looking through the previous posts, but cant find the answer to my question.
Is the second factory battery that comes with the car, there for starting purposes only or is there another reason for the second battery, i.e electronics power for computer etc etc??
I was looking at splitting them with a battery seperator management system
Regards Brooka27
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Oct 28, 2006 at 23:24
Hi Brooka
You need high torque for the diesel.
You have two options.
Fit 2 heavy duty batteries with an isolator. Redarc or ABR unit.
Fit a 3rd battery. Kits are available.
Let me know what you need to run.
Regards Derek.
201510
Reply By: Darian (SA) - Sunday, Oct 29, 2006 at 08:40
I had the same query - ran it past the team at Lcool100 - they suggest that the stock factory setup is two medium batteries wired parallel (no controller between) - just like a big battery but in two halves (guess it aids weight distribution). Seems if you want to convert the second one to an auxiliary function, via a controller of some sort, the primary unit will be probably be too small. Upgrade of the primary at least, seems certain.
201528
Reply By: Crackles - Sunday, Oct 29, 2006 at 16:51
The original twin batteries in a TD100 are to give more power for starting & running the cars electrics, not for additional assesories as such.
There is an option Brooka that is ideal for the TD 100. Replace both batteries with 2 x 130AH deep cycle or AGM batts leaving them wired in parrallel. With 260AH you have enough power to run a car fridge & lights for at least 3 days & nights with plenty of reserve to start the engine. To avoid running the batteries flat you could wire all assesories through a relitively cheap low voltage disconnect switch set to cut out around 40%. This system does away with an expensive isolator all together, a device which in the wet, dusty & hot confines under the bonet seem to fail on a regular basis.
Not only does the starter crank the engine over much faster, this system ensures no one battery running assesories is deep discharged below 30% & both batteries charge up together evenly resulting in a long battery life.
Cheers Craig........
HZJ105 Vic
Twin 115AH deep cycle Trojan's.
201576
Reply By: White Knight - Sunday, Oct 29, 2006 at 20:57
Hi Brooka, just wish to mention, depending on the year of your LC (if still under warranty), if you split them, I've been told you will null in void your new car warranty. I'm going through the same issue at the moment, so what ever you come up with, I'd sure be interested in chatting. I do like the sound of upgrading the standard batteries, but this would incur a rather larger bill. The 3rd battery through ARB, seems to be quiet small (55 amp). The only thing l have come up with so far, is to buy a gel or dry cell battery and mount it in the car. If you could email me in the way you go about it, l would appreciate. thanks
201648
Follow Up By: Brooka27 - Friday, Nov 03, 2006 at 01:07
I have finally had my car delivered. The two batteries have been seperated already with a Cole Hersee four pole switch.
Ex Police vehicle!
Battery 1 is a Delkor 90AH, CCA 710.
Battery 2 is a Power Breed Deep Cycle 75AH.
Both batteries have been seperated by the negative side of each battery to the starter motor negative. Apparently this allows the option of switching from Battery 1 to Battery 2 to BOTH or to the OFF position.
I spose this allows me to run my car fridge and extra lights off battery 2, without drawing charge of battery 1 by switching the selector to battery 2 ONLY.
This is a new system of isolation for me as I have had the ARB smart switch setup in my old 80 series, this isolated the positive side and not the negative.
Will keep you updated with what I will come up with in the future.
Regards Jason.
462280
Reply By: Richard W (NSW) - Sunday, Oct 29, 2006 at 21:17
From my recollection there was no definitive answer on 100sCOOL however there was one suggestion in was for the colder climate countries.
In any case I have put a 100AH AGM in th rear, charged through a Pirahana isolator and hooked up to 4 fused 16amp sockets and a 300W inverter.
201670
Reply By: Member - Davoe (Nullagine) - Sunday, Oct 29, 2006 at 21:27
2 batterys are deffinitly not needed to start a turbo cruiser as they run lower compression than a dunger 1hz with one battery and the same donk in the TD 79 runs off one battery. I believe you need to change some wiring and fit a couple of decent batterys with a seperation system - no worries
201674
Reply By: Brooka27 - Monday, Oct 30, 2006 at 21:28
Thanks to all, I will keep you updated with what I come up with.
Regards Brooka27 W.A.
201904
