TD42 precleaner
Submitted: Monday, Oct 30, 2006 at 03:39
Barnesy
Does the air precleaner on some 4.2 diesel GQ's actually do anything? I have heard about people removing them and having no problems. I will be putting a
snorkel on my GQ and wondering whether to remove the precleaner or not. Advice is appreciated.
Barnesy
Reply By: Barnesy - Monday, Oct 30, 2006 at 03:53
Another question please, would a
snorkel from a MQ Patrol fit a GQ? They seem to go a shorter distance on the outside of the guard and look better. I know the two models have the same body but i want to be sure.
201737
Reply By: Member - Brian (Gold Coast) - Monday, Oct 30, 2006 at 07:26
Barnesy
Mine was removed when we put the
snorkel on it.....no drama's... and now a Finer Filter sit's there since the turbo was fitted....
Don't know about the MQ one fitting....
Brian
201739
Reply By: Willem - Monday, Oct 30, 2006 at 09:04
Mine was removed when the Safari Snorkle was fitted. Doesn't seem have had any detrimental effect. When travelling on overgrown tracks I do get a bit of leaf litter accumulating in the aircleaner body and check it regularly. The filter stops any ingress of foreign matter however.
201752
Reply By: Black Beard - Monday, Oct 30, 2006 at 09:20
I think you'll find the MQ one is shorter than the GQ because the air filter sits higher and up the back of the engine bay in the MQ, where the GQ air intake is towards the front behind the headlight. Cheers...
201756
Follow Up By: Barnesy - Tuesday, Oct 31, 2006 at 00:49
that's true black but a little length of tubing inside the guard can fix that. do you know if the MQ
snorkel will fit the GQ? the GQ has flared guards too. i can't just go down to ARB or tjm to have a look as i ive in the country.
461408
Reply By: Member - 'Lucy' - Monday, Oct 30, 2006 at 09:56
Nup!
201762
Follow Up By: Member - Jeff H (QLD) - Monday, Oct 30, 2006 at 10:59
Miss-dee-Loosie, an unusually short response to the owner of 'that' brand. Come come, they may develop a complex.
461155
Follow Up By: Member - Roachie (SA) - Tuesday, Oct 31, 2006 at 04:14
He's too busy concocting his "story" of the rest of his KI trip to be able to give a longer reponse to this question.................plus his knowledge level on the subject is somewhere between "nil" and "zip"......hahahahaha
461427
Reply By: Truckster (Vic) - Monday, Oct 30, 2006 at 13:06
I removed
mine as the outlet on the precleaner box is about 1/5th the size of the inlet.
Take it off and have a look at the squashed plastic pipe on the bottom of it..
Run a hose straight from inner guard to airbox.
I have my old one at home if anyone wants it.
201789
Reply By: honestjohn - Monday, Oct 30, 2006 at 20:16
mine was removed when the safari
snorkel went on i have a piece of aluminium
flyscreen over the head of the
snorkel i find it stops all the bugs hoppers etc and easier to clean
201868
