safari snorkles
Submitted: Monday, Oct 30, 2006 at 07:39
Member - len W (NSW)
Site Link
do i realy need one??? lol............... len
Reply By: Member - Jiarna (NT) - Tuesday, Oct 31, 2006 at 00:49
Yes
201966
Reply By: Rob from Cairns Offroad Training & Tours - Tuesday, Oct 31, 2006 at 12:56
Not for
water, if its so deep you need a
snorkel, its too deep. A tarp over the bonnet is $10 a
snorkel $500+ Its a no brainer. Cheers Rob
202034
Follow Up By: Off-track - Tuesday, Oct 31, 2006 at 15:44
Until you stop in the
water then ya up for $$$ when the engine takes a drink.
461548
Follow Up By: Voxson (Adelaide) - Wednesday, Nov 01, 2006 at 07:54
"A tarp over the bonnet is $10 a
snorkel $500+ Its a no brainer."
I dont get how its a no brainer?
What if you are crossing a boggy river and you have to slow down so the tarp is no longer effective and the
water is bonnet depth?
461701
Reply By: Shaker - Tuesday, Oct 31, 2006 at 15:24
You don't need one .... until you hydraulic your motor, then the
snorkel will seem to have been very, very cheap!
202059
Reply By: Member - Stephen M (NSW) - Tuesday, Oct 31, 2006 at 19:32
Doing
water crossings higher than the original air intake from factory then yes, if you do a lot of dusty roads then yes get the air intake nice and high and suck in less dust then under your wheel arch, dont go off road then no. $500 is jacksh@t for a bit of piece of mind when you happen to stall in the middle of a
water crossing and lock it up costing you $10g+ for an engine rebuild in the middle of now where. Just my opinion as usual. Regards Steve m
202129
Follow Up By: bob&loz - Tuesday, Oct 31, 2006 at 20:32
If you stall it a
snorkel is not going to help you
unless you have one on your exhaust as
well
461623
Follow Up By: Off-track - Tuesday, Oct 31, 2006 at 23:22
Not if the engine is kept running.
461680
Follow Up By: bob&loz - Wednesday, Nov 01, 2006 at 20:03
Sorry but when you have "stalled" it means your engine has stoped running
461858
Follow Up By: Off-track - Thursday, Nov 02, 2006 at 00:58
Ahh yes my mistake!
461942
Reply By: Richard & Leonie - Tuesday, Oct 31, 2006 at 21:54
Go to the Safari web site and have a look at the old Jackaroo try to swim. Then get a
snorkel.
Richard
202176
Reply By: Member - Alan (WA) - Wednesday, Nov 01, 2006 at 02:18
If you have a
snorkel and only crossing
water within limitations, why do you see some people still using a "car bra" / tarp over front? Is this really necessary, or is this more a case of belts and braces?
202214
Follow Up By: Voxson (Adelaide) - Wednesday, Nov 01, 2006 at 07:58
I believe it is a good idea to try and keep as much
water out of your fan blades as possible, so when it is quite deep i also use a bra.
461702
Reply By: Member - Andrew (QLD) - Wednesday, Nov 01, 2006 at 08:06
Everyone knows Airtec snorkels are better
202223
Reply By: Flash - Wednesday, Nov 01, 2006 at 14:39
How's this......Two friends of
mine (
Well, one is a good friend anyway), identical 3 litre Patrols did many many hundreds of klicks on dirt recently, sharing about 50/50 in front and behind.
One had a
snorkel, one didn't.
One went through three air filters, while the other (with the
snorkel) went through less than one, ie: it was still OK.
True story- enough to convince me to get one. Cheers
202280
Reply By: Alloy c/t - Wednesday, Nov 01, 2006 at 17:40
If for no other reason , fuel economy ,since fitting the
snorkel we get an extra 1k per lt in stop / start city traffic and 1.5 k per lt on the h/way ,,cleaner/ cooler air than from inside a mudguard ,less twists and turns to the air filter.
202319
Reply By: Bware (Tweed Valley) - Wednesday, Nov 01, 2006 at 17:53
Nice one, Len. LOL
My canoe was cheaper than a
snorkel ;-))))
202321
