changing awd to part time
Submitted: Monday, Oct 30, 2006 at 19:59
ThreadID: 38977 Views:1721 Replies:3 FollowUps:4
Help has any one changed their 80 series from AWD to part time. If so has this improved fuel usage.Very heavy now on either gas or petrol
Reply By: Crackles - Monday, Oct 30, 2006 at 21:13
Haven't done the mod personally but have it on good authority that on a 1HZ diesel they got on average 2 MPG better & a few KPH faster top speed. Not really the result one would need to recoup the install cost.
Cheers Craig...............
AnswerID: 201890
Follow Up By: djm67 - Monday, Oct 30, 2006 at 21:27
......add the savings of wear & tear of your driveline and it will start to look better.
Kits start under $600 for a self install, have a look at 4wdsystems or marks
FollowupID: 461313
Reply By: HJ60-2H - Monday, Oct 30, 2006 at 21:33
Nissan Trials are on this weeked north of Widsor, just out of Sydney.
Sure to be a few 80's get converted to part time drive there!!
AnswerID: 201906
Follow Up By: donks1 - Tuesday, Oct 31, 2006 at 08:18
hi hj60
do you have any more info on the trials
wouldn't mind going out for a look
thanx
FollowupID: 461447
Follow Up By: HJ60-2H - Tuesday, Oct 31, 2006 at 09:34
Sure, go to their WWW site and the details are there. Always a good weekend I reckon. Just like the TLCC Challenge and Woodpecker events.
www.nissanpatrolclub.org/
FollowupID: 461469
Reply By: Member - Scott M (NSW) - Monday, Oct 30, 2006 at 21:47
My brother did it on his 80 series GXL. This post (under Matt M(ACT)) gives an idea
Site Link
AnswerID: 201913
Follow Up By: Member - Scott M (NSW) - Monday, Oct 30, 2006 at 21:54
I quote Matt's response:
" Member - MATT M (ACT) replied to the question
Brett,
Had my '94 Petrol 80 series done just before Xmas and so far very pleased with the result. I originally took the car in to address a worsening transmission snatch problem and was advised to go for the part time conversion. Cost about $1300 and has certainly had a positive impact on fuel consumption as well as eliminating the ugly snatch. Granted, it will take a long time to make up the $1300, but it would have cost me about that to fix the problem and restore the original configuration anyhow. The car seems lighter to steer and a bit more enjoyable to drive.
Now the centre diff lock button engages 4wd and , of course, the hubs need to be locked. 4wd still engages automatically on selecting low 4. Only disadvantages are:
- Getting out of the car to lock hubs (very uncivilised but the kids have become experts at it on demand)
- Cost (but sounds like you are up for repairs anyhow)
- Centre diff lock now taken out of play. I guess that this makes the vehicle slightly less capable as the car now has a permanent limited slip centre diff (no expert on this but I believe that this is the way it now works).
The only other issue I have found is that it has also accentuated (but not worsened) some slop in my rear diff. I need to have this fixed but would have to have done it anyhow before we dissappear on the round Australia jaunt in the second half of this year.
Overall, very happy with the result. Not such a problem with the diesel, but anything I can do to reduce petrol consumption in mine is welcome.
Hope this helps,
MATT "
FollowupID: 461334
