Where can I get electronic Maps of Vic High Country??
Submitted: Tuesday, Oct 31, 2006 at 09:09
ThreadID: 38991 Views:2039 Replies:4 FollowUps:7
Can anyone tell me where I can get 1:25000 maps of the Vic High country? i have the 1:250000 rasters but would like more detail.. even 1:100000 would probably be enough. Thanks in advance..
Reply By: Shaker - Tuesday, Oct 31, 2006 at 09:13
I think the Rooftop map series are available in electronic format.
AnswerID: 202001
Follow Up By: Member - nrb1748 (VIC) - Tuesday, Oct 31, 2006 at 09:54
They are, and provide good detailed information.
nrb1748
FollowupID: 461477
Follow Up By: Mike Harding - Tuesday, Oct 31, 2006 at 10:09
Ensure they cover the areas you want - they don't (thankfully) cover a fair bit of the HC - an "interesting" character is Robin R.
Mike Harding
FollowupID: 461482
Reply By: Member - nrb1748 (VIC) - Tuesday, Oct 31, 2006 at 09:58
Just checked. They are available from the EO Shop.
nrb1748
AnswerID: 202006
Follow Up By: Member - Coyote (SA) - Tuesday, Oct 31, 2006 at 10:07
Thanks but I must be going blind... I found a coupe of paper maps, but no electronic.. can you give me mmore specific details on where you found the maps in the EO shop? Cheers
FollowupID: 461481
Follow Up By: Member - Andrew (QLD) - Tuesday, Oct 31, 2006 at 10:13
type in "Rooftop" into the site search function on the left hand column......easiest way normally :-)
FollowupID: 461484
Reply By: Member - Coyote (SA) - Tuesday, Oct 31, 2006 at 10:24
Well I'll be Jiggered... Learn soemthing new every day. I've been on ExplorOz for a year or so and never used that ... not until now and forever after that is.. Ta for that..
AnswerID: 202012
Follow Up By: ExplorOz Team - David - Tuesday, Oct 31, 2006 at 11:44
I just noticed a bug in Site Search that is not showing the images for shop items - I will attend to that today a direct link to Rooftop maps in the shop is this:
Site Link
If you go to the shop you can select any titles by brand and the above link is a Rooftop Maps brand search. As mentioned normally site search works and will result in the product plus after today the images.
FollowupID: 461500
Follow Up By: ExplorOz Team - David - Tuesday, Oct 31, 2006 at 12:38
The image bug in the site search is now resolved. Thanks.
FollowupID: 461509
Follow Up By: Bonz (Vic) - Tuesday, Oct 31, 2006 at 19:04
Good Job Gumshoe
FollowupID: 461599
Reply By: Member - Coyote (SA) - Tuesday, Oct 31, 2006 at 11:49
Thanks David.. very helpfull indeed
AnswerID: 202025
