Jeep Wrangler Radiator Hoses
Submitted: Tuesday, Oct 31, 2006 at 14:35
Brian B (QLD)
Hi Folks,
My son has a late model Jeep Wrangler and he wants to get a new set of radiator hoses. From advice he has been given it would appear that you can only get these from Jeep at a cost in excess of $300.00 for the pair. The explanation he has been given for this is that the Jeep
water pump is very strong and that without these hoses which apparently are internally reinforced over normal hoses, the pump will suck them flat causing overheating and the possible big bang we all try to avoid.
Does anyone out there know if this sounds right and or any alternate supplier of hoses that would fit the Wrangler?
Thanks for your help.
Reply By: Member - Uncle (NSW) - Tuesday, Oct 31, 2006 at 15:16
Hi Brian, try Mascot motors in the flinders industrial estate at Nowra 02 44218111 they are the jeep wreckers specialist.Might be worth a try.unc
202057
Follow Up By: Brian B (QLD) - Tuesday, Oct 31, 2006 at 20:27
Thanks mate.
461617
Reply By: banjodog - Tuesday, Oct 31, 2006 at 16:07
Also try Hammond 4WD Centre at Capalaba.
202069
Follow Up By: Brian B (QLD) - Tuesday, Oct 31, 2006 at 20:28
Thanks.
My son has had some
suspension work done there and they seem pretty good on jeep stuff.
461618
Reply By: Exploder - Tuesday, Oct 31, 2006 at 19:58
“The explanation he has been given for this is that the Jeep
water pump is very strong and that without these hoses which apparently are internally reinforced over normal hoses, the pump will suck them flat causing overheating and the possible big bang we all try to avoid.”
What a load of Chit.
Tell him to order in a set from the U.S from hear.
www.summitracing.com/
These guys’s are Big and stock a lot of parts Aftermarket or OEM for anything American and will ship parts fast; I have had parts delivered to my door in 6 days from them.
I have used them a few times in the past with 0 problems and have saved a lot of $$
I looked throe there Online catalogue and found Goodyear Replacement Hoses for, Jeep wangler 2000 4litre for around U.S$10, Sure beats $300
hay LOL. They are also helpful in identifying the correct part’s if you call them.
Cheers.
202135
Follow Up By: Brian B (QLD) - Tuesday, Oct 31, 2006 at 20:31
Exploder,
Thanks for the great info.
I will pass it on to my son.
Have a good one.
461621
Follow Up By: Stu-k - Wednesday, Nov 01, 2006 at 10:45
Like most rad hoses they will have a spring in the bottom hose to stop this, its normal and shouldn`t cost big $$$$
461733
