100s Instrument Cluster Tacho
Submitted: Tuesday, Oct 31, 2006 at 14:46
ThreadID: 39005 Views:2485 Replies:5 FollowUps:2
Gday All,
For some time now my tacho has been behaving erratically. At first i thought it was the bumpy roads / off road driving but it is now permanently unreliable on any road. It jumps up and down and all over the place - and sometime just refuses to budge off "0".
I got a quote from my local tojo dealer for a replacement instrument cluster for a 1998 hzj105 GXL and was stunned to find it cost $1490.00 for a new cluster!!!
I know it comes as a complete unit and that you cant seperate the instruments - but does anyone know if you can put an aftermarket VDO type tacho from the sensor on the fuel pump? That way i could just ignore the factory tacho and have my aftermarket one elsewhere.
Or can you get them cheaper anywhere else?
Anyone else got a way around this?
Quartzy
Reply By: hilux steve - Tuesday, Oct 31, 2006 at 16:25
Hi Quartzy
Send me your vin no. and i will see if i can get a part no. for the just the tacho, you can get just the instruments in some models, instead of the whole cluster
Steve
AnswerID: 202074
Follow Up By: Quartzy - Tuesday, Oct 31, 2006 at 19:57
Gday Steve,
Are there any security issues posting a vin number on a forum?
Got an email address to send it to?
Quartzy
FollowupID: 461610
Follow Up By: hilux steve - Wednesday, Nov 01, 2006 at 07:59
Hi Quartzy
Send it to stephen.thomas@melbcitytoyota.com.au
Steve
FollowupID: 461703
Reply By: kesh - Tuesday, Oct 31, 2006 at 18:11
Quartzy. Why dont you check the sender unit (where ever it is, injection pump?) It could very easily be a faulty connection there rather than a fault in the tacho electronics.
kesh
AnswerID: 202104
Reply By: Rob from Cairns Offroad Training & Tours - Tuesday, Oct 31, 2006 at 20:13
Early 100 series had a fault with instrument clusters. Mine was one of many replaced under warranty up here. Cheers Rob
AnswerID: 202140
Reply By: Quartzy - Tuesday, Oct 31, 2006 at 20:25
Cheers Rob and Kesh.
Thanks for your input on this problem.
Quartzy
AnswerID: 202142
Reply By: Kevin1243 - Tuesday, Oct 31, 2006 at 20:58
My 80 series tacho was the same and it turned out to be a bad earth connection under the drivers side kick panel. I also noticed to voltage dropping when headlights or power windows were used.
The way it's gotten worse over time suggest some sort of bad wiring connection.
Kevin
AnswerID: 202151
