Washing 4x4 after beach trip in drought
Submitted: Thursday, Nov 02, 2006 at 18:50
ThreadID: 39087 Views:6520 Replies:11 FollowUps:10
Today I had a fun day fishing on the beach at Bribie Island. When driving up the beach I had a thought. "How do I get the salt and sand off the vehicle". Here in South East QLD we are on Level 4 water restrictions. That is wash the vehicle with a bucket filled directly from the tap. NO hose.
I recall visits to the local car wash on previous occasions leaves a lot to be desired in the cleansing of the under body portions.
Any advice on how to clean will be appreciated as I have purchased a yearly permit at a greater cost than the ABC (30 cents per day) which I wish to utilise more extensively.
Thanks in advance
Redeye
Reply By: stevesub - Thursday, Nov 02, 2006 at 18:59
We live on Bribe and use a car wash in Caboolture or Caloundra - not very satisfactory, but all we can do without installing a water tank and pump. I use the pressure "Car Lovers" type of car wash - but remember, they are recycling a portion of their water (complete with diluted salt).
Other than that pray for rain and heaps of it on the dams.
Stevesub
AnswerID: 202634
Reply By: Alloy c/t - Thursday, Nov 02, 2006 at 19:01
Car lovers , Laserwash has an underbody option ,, just drive in Reeeeeeeel slow ,do the wash and the mega blast drying ,u wont find any sand left in any nooks or cranies ,, as for the yearly pass ,$100 , cheaper than 1 barge trip to Moreton.
AnswerID: 202636
Reply By: Willem - Thursday, Nov 02, 2006 at 19:18
Redeye
A small 12 volt pump should do the trick. Put water in 10lt plastic paint bucket or such and maybe fit a sprinkler nozzle to the outlet. That way we will not be breaking the rules and you should be able to wash the underbody of your truck with ease
AnswerID: 202638
Follow Up By: Member - Toytruck (SA) - Thursday, Nov 02, 2006 at 22:39
Willem,
not sure of the QLD restrictions but I was on the SA water site the other day checking about the restrictions currently in place here. On the site it currently states that the use of a pressure cleaner fitted with a water saving head remains legal to use for "rinsing" a car. Now I am not sure what they mean by rinsing but I am still using my Karcher (with the miser head) to blast my Landcruiser after a trip out, possibly every second weekend, and I must say "Rinsing" only if I need to scrub then its back to elbow grease. Again, not sure about Qld Level 4 but rinsing is rinsing and washing is washing.
Toytruck
FollowupID: 462237
Follow Up By: robak (QLD) - Friday, Nov 03, 2006 at 16:24
A 10 litre plastic bucket of water wouldn't last very long, but if you were to place that plastic bucket underneath a flowing tap......
FollowupID: 462427
Reply By: wazzaaaa - Thursday, Nov 02, 2006 at 19:58
Hi, we live in the redlands and we are still on level 2 water restrictions, we can still use the hose to wash the car any time as long as it has trigger or twist nozzle, a high pressure water cleaning unit with a trigger nozzle and/or buckets filled directly from a tap. Do you know anyone in the redlands, maybe use their water if you cab.
Wazza
AnswerID: 202647
Reply By: Exploder - Thursday, Nov 02, 2006 at 20:33
Wait till 1 in the morning then get out there and go nuts with the hose when nobody is around. He he he
AnswerID: 202660
Follow Up By: Alloy c/t - Thursday, Nov 02, 2006 at 20:52
He He He , legaly wrong , but even worse , no sense of morals or community , attitude such as yours reflects on all 4x4 .
FollowupID: 462184
Follow Up By: Exploder - Thursday, Nov 02, 2006 at 21:09
It’s the only way to get thro alive in this F**ked up world.
Sorry
Excuse me I need to go and scrap the dog I hit off my Bulbar before the owner finds it, and empty 30Ltres of used engine oil from my 4WD into the bin so it can go directly to land fill, Then I will go and get some fuel making sure to drive off without paying . LOL
FollowupID: 462190
Reply By: Mikee5 (QLD) - Thursday, Nov 02, 2006 at 21:17
The Queensland governments since they canned Wolfedene dam have been bragging about 1000 people a week moving to Qld and then not building the infrastructure (roads and dams) to cater for them. Down the road to me they are building a 20 storey residential tower, how much less water must I use to allow this building to operate? They I drive past car yards who wash their entire stock every morning. Fill a bucket from the tap, use a bilge pump and hose your car. OR - rust in a car is a safety issue, hose your car and threaten to sue anyone who tries to stop you on road safety grounds. You can hose boat trailer brakes and suspension and you can use a flusing device on your outboard, just where you draw the line on safety has not been tested yet.
AnswerID: 202677
Reply By: Redeye - Friday, Nov 03, 2006 at 07:02
Thanks all,
Some interesting suggestions.
As it is so dry here I will also use a air pressure hose to remove most sand. There is little sand under the vehicle because it is so dry.
Then will attempt to run my high pressure cleaner from a bucket today. Do not know if it will work by sucking the water in but worth a try. This may also be beyond the legal limits that are applying with level 4 as I am restricted from filling my fish pond and the bird bath with tap water :(
We are expecting rain tonight so may look for some puddles in the road to drive through.
Thanks again
Redeye
AnswerID: 202748
Follow Up By: madmav - Saturday, Nov 04, 2006 at 22:57
I use the pump from my Glind shower to suck water from the bucket then feed that into the pressure cleaner.Works great I guess you could use a bilge pump too let me know how you go.
FollowupID: 462659
Reply By: Member - BBB - Friday, Nov 03, 2006 at 07:34
It wont fix your proble now but take advantage of the Water Tank rebates from the State Goverment and BCC it will cost you nothing after the rebateit
If you where a member I could send you the details of a Plumber that is doing this work for the rebate costs.
Or if you want to put your details up I will contact you.
BBB
AnswerID: 202750
Follow Up By: Redeye - Friday, Nov 03, 2006 at 09:35
Thanks BBB
Live in Caboolture and do not know if the rebate applies here.
Had a tank once and pulled it out. Doubts over the super 66 roof (asbestos) on the house and other foreign matter from vehicles saw mills etc in an urban society.
Understand what you are saying though and thank you
Redeye
FollowupID: 462332
Follow Up By: Member - BBB - Friday, Nov 03, 2006 at 23:02
The State Goverment one does but ring CCC about the loacal Goverment rebate
FollowupID: 462500
Reply By: Cruiser HZJ70 - Friday, Nov 03, 2006 at 10:24
A word of advice to anyone who finds themselves in trouble with Brisbane City Council regarding water use-
I had just finished using the watering can to wash my vehicle a few months back when I had a "Water Inspector" approach me for unauthorised use of water. Turns out my B!TCH neighbour reported me for using the hose to fill my watering can.
I very calmly explained to the bloke that I was using the hose because it saved all the spillage associated with angling the can under the tap and trying to get most of the water in the small hole at the top of the can. I also pointed out how small the puddle was that had run off my vehicle. I made sure he noted these points in his note pad along with the fact that he didn't personally see me use the hose.
He then told me his notes would be reviewed before a decision was made to send me a fine in the mail or not. (A good way to avoid the confrontation of handing me the fine on the spot I thought).
A week later it came. $150 for my "first offence". Quite P!SSED OFF at this stage, I filled in the section on the back to have the mater heard in court, assuming that any magistrate with an ounce of common sense would see my point.
About six weeks after that I got a phone call from Brisbane City Council. The bloke asked me to confirm my intentions to go to court. When I did, he asked me on what grounds. I told him I would not discuss the matter over the phone and I would have my say in court.
Less than two hours later he rang back and told me BCC would not be pursuing the matter any further as the woman who reported me was not prepared to appear in court.
The main thing I would like to point out here is that unless the Council officer is prepared to say under oath that he personally seen you use water in an unauthorised manner, it'll be thrown out of court.
The stupid thing about these "Band aid" water restrictions is the same B!TCH that dobbed me in probably spends an hour in the shower each night. How would we know?
AnswerID: 202773
Follow Up By: Wazza - (Vic) - Monday, Nov 06, 2006 at 21:34
Turn her water mains off with a 24" stilson ...... about 3 minutes into her shower. What a scrag.
FollowupID: 463003
Reply By: troopyman - Friday, Nov 03, 2006 at 13:03
My wife saw an ad for a 5000ltr poly rainwater tank with a pump and all connected for $99 after the rebate . Thats what im doin .
AnswerID: 202808
Follow Up By: Alloy c/t - Friday, Nov 03, 2006 at 18:54
Only problem with that is that now its almost a 6mth wait to get your tank ,, probably have a flood like "74" before can get the tank. ,,weve been waiting and waiting for our tank for 10 weeks.
FollowupID: 462453
Reply By: G.T. - Monday, Nov 06, 2006 at 18:58
Interesting replies from various people. I live on the Gold Coast and think that using a bucket to wash a vehicle is more of waste of water than using a wash brush. To my knowledge there is no restrictions of how many baths a person can take in any one day.
Take as many baths as it requires to wash your vehicle. All you have to do is that you do not pull the plug but bucket the water out and use it to wash your vehicle with pumps etc as described previously. You can say to any water inspector that this is a conservation measure as you would normally pull the plug on your bath water and you should be congratulated for being a fine upstanding citizen. It is none of his business of how many baths that you take , or for that matter of how many baths other family members take per day. This way you get a squeaky clean vehicle and family. Regards G.T.
AnswerID: 203384
Follow Up By: Alloy c/t - Monday, Nov 06, 2006 at 19:09
YES YES YES ,,,the real true spirit of water conservation ,, never mind that we are in a drought ,just make sure you smell nice and your car is clean ,never mind [insert sarcasm].
FollowupID: 462978
