Gadget prices;uhf;thanks Stephen L.
Submitted: Friday, Nov 03, 2006 at 21:27
ThreadID: 39139 Views:2734 Replies:5 FollowUps:3
'Andrews Communications' offered the best price I could find on GME TX-610 hand held unit plus 'ciggy light trickle charger @$97 total (post inc). Next best was Prestige Communications, who've served us well in the past.
Any other links to consider?
Thanks eh Steve.
Ditto to other assorted misfits who've been of comfort recently.
(PLEASE read this post rapidly, before The Boss sees it and cans it as well)
Travel safe, and may that rumoured rain drop into your patch. Jeff H.
Reply By: Member - Stephen L (SA) - Friday, Nov 03, 2006 at 22:03
Hi Jeff
That what this site is all about, all helping each other out.
I hope you get much use out of the Radio.
AnswerID: 202938
Reply By: Member. Rob M (QLD) - Friday, Nov 03, 2006 at 22:17
Jeff,
Give Olbis at Rocklea a call they have always been competative with there pricing and are local if warranty issues arrive.
Rob M.
Rob M
AnswerID: 202940
Follow Up By: Member - Doug T (W.A) - Friday, Nov 03, 2006 at 23:50
I was going to get my Icom from Olbis, and they were going to charge an extra $75 to program the other 88 channels in so I went to Access Electronics in Cloncurry and they were $10 cheaper and was no charge to program it, I'm not knocking Olbis , I have spent a few hundred dollars there , even when their shop was on Ipswich Rd Oxley near the where the Oxley Rd Roundabout is
FollowupID: 462510
Reply By: Derek from Affordable Batteries & Radiators - Friday, Nov 03, 2006 at 22:45
It is a 1 watt unit.
Not real good. Best to go for 4W or 5W.
If you are not in a hurry I have units arriving in the next few weeks.
Millitary grade UHF 99 ch.
Regards Derek.
AnswerID: 202946
Follow Up By: Member - Jeff H (QLD) - Friday, Nov 03, 2006 at 23:02
Thanks Derek, but cheque is in the mail: just need a "voice back to car unit", and both Andrews and Prestige scrubbed the others by around 30%(min).
I must admit that Olbis didn't figure, as they were far from competitive (and not particularly user friendly), 3 years ago. If they've lifted their game, I apologise for any aftersmell, and would urge all (esp. SE Qld.) folk to give 'em a go. JH.
FollowupID: 462501
Reply By: Member - Doug T (W.A) - Saturday, Nov 04, 2006 at 00:12
Actually this bloke in Nambour has got some really good gear ,check out the CBs,I got a Magnum Delta Force from him a couple years back. It has USB,LSB, FM and AM , and don't think FM means UHF it is FM on the HF frequencies
Features: PLL Synthesised mobile all mode tranceiver with large illuminated LCD Digital Bargraph Display, 5 digit LCD frequency readout Frequency: 25.160 - 29.700MHz (Export Version) Frequency Tolerance: 0.0005% Frequency Accuracy: 110ppm or better Output Power: 30watt AM/SSB/CW PEP & 25watt max. FM Spurious Emission: -60dB or better Carrier Suppression: -40dB or better Meter Functions: Signal S/RF, RX Receive Signal Strength, Modulation, SWR Calibration, SWR Others: Mic - 600 Ohms, Dynamic PTT Dimensions: Size 2 3/8" x 7 7/8" x 9 1/4" Weight 1.8kg
Manufacturer: DeltaForce
$549.00 incl. GST
www.syncroelec.com.au/
Doug
AnswerID: 202966
Reply By: Member - Doug T (W.A) - Saturday, Nov 04, 2006 at 00:17
Jeff
How ya going ya old queenslander
I just checked out Synchro's UHF .look at the specs on it eh and the price is good too
FEATURES: 40 Channels UHF CB 360 Additional receive channels Roger Beep (switchable), Beep (switchable) Duplex - Repeater access, Priority Channel Large LCD display, Monitor, TX/RX signal bar Scanning (memory - skip - priority) Telemetry and simplex repeater ready, CTCSS sub audible tone squelch (50 Tones)
https:// Site Link
Doug
AnswerID: 202968
Follow Up By: Member - Jeff H (QLD) - Saturday, Nov 04, 2006 at 02:35
Dusty, you didn't act on my email?
Not-so-good-dog.
Then again, maybe it's this daylight-saving time warp that slows electronic transmission across the 3hr sun gap.
(That could mean up to 6 hrs before Bossman wipes an irrelevant [to many] post.)
Doug, had a look, but didn't see: will revisit tomorrow. Stay safe Pilot. JH.
FollowupID: 462531
