stat writeoff policy laws ect
Submitted: Sunday, Nov 05, 2006 at 11:13
mr polar
stat writeoff what can be used in rebuilding/ example ( vehicle is a stat writeoff submergered in fresh
water vin chassis and body numbers registed as stat writeoff cant be used right? can you buy chassis and body shell not on register and tranfer all parts into vin chassis body? if so why are they stat writeoffs as chassis and body cant really be damaged by fresh
water.Also can you get a repairable wreck body badly damaged and switch the tags as fresh
water does not damage the body.someone out there must have dealt with this situation?any info would help cheers mr polar
Reply By: Sarg - Sunday, Nov 05, 2006 at 14:05
I bought a Stat.write - off a few years ago, but only to get the mechanicals & electrics from that vehicle to rebuild another that happened to go for a swim too.The donor vehicle had hit a tree sideways & the chassis & every panel except the right rear door was stuffed.The VIN No. etc were recorded & removed & lodged with the Rego mob so it can"t be re-used. After stripping every thing off that I wanted, the leftovers went to the recyclers. Cant see why you couldn't use body panels etc on another vehicle, so long as you don't try to use the writeoff chassis to build something that you will want to rego.
203175
Follow Up By: blown4by - Sunday, Nov 05, 2006 at 22:34
There are two types of "write-off's" on the written off vehicle register (WOVR). The economic write-offs are deemed by the insurance company concerned to be un-economic to repair can legally be repaired and re-registered and must pass an inspection first as does any unregistered vehicle and in WA it costs $56.50 for the first inspection and $39.10 for re-inspections should it fail the first time. You have to produce original invoices, receipts, etc for the parts & labour used to repair the vehicle and if the parts are second-hand the VIN from the donor vehicle the parts came from is required. The second type is the statutory write-off and these vehicles can never be re-registered but parts can be used off them to get another vehicle roadworthy. I am pretty sure but may stand corrected that any vehicle when fully submerged in fresh or salt
water is classed as a statutory write-off.
462854
Follow Up By: Sarg - Sunday, Nov 05, 2006 at 23:45
Thats what I said. I bought a structualy damaged vehicle (Stat write - off) to repair a" economic write - off ", although the vehicle was never insured anyway. Just a cheap source of parts.
462860
Reply By: Member - Shane D (QLD) - Sunday, Nov 05, 2006 at 18:41
In Qld once the vehicle has been written off, the VIN no. goes on to a register.My neighbor's car was written off in an accident(borderline repair)but because of a whole heap of insurance/finance co. drama he had to get it fixed.Once it gets fixed it has to be inspected by a special division of Qld transport for a fee of $550 to be removed from the write off register,so, yes you can use a write and get it registed (IN QLD)
203201
Follow Up By: mr polar - Sunday, Nov 05, 2006 at 19:51
did he remove vin tags from one body to the other?also is a repairable writeoff taken of the list once it has passed a inspection?
462795
Follow Up By: Member - Shane D (QLD) - Sunday, Nov 05, 2006 at 21:16
his car was REPAIRED after being declared written off
he had not long bought it, but the finance owing and the insurance payout ,WAY different numbers so it was decided to be repaired (NOT BY HIM).I cannot tell you if it remains on the register but there is a process in place up here (QLD)
I've been in wrecking yards looking for parts when wrecks have come in from an auction yard displaying stickers on the windscreen stating that this vehicles is a repairable write-off and has been registered as such,perhaps there is some sort of write off grading system that identifies vehicles that are borderline repair/write-off & vehicles that are good for scrap only and that could be potential "ID donor's" which is why they have an intense government rego inspection(not an ordinary rego looky) to see if it has had a rebirth, ie stolen car with write-off cars VIN(that's why it has to go to a special inspection
462834
Reply By: Dave ....Adelaide - Sunday, Nov 05, 2006 at 18:46
in S.A you cant reregister a stat writeoff, but you can us any of the body parts apart from chasis or anything else that has VIN stamped on it ...any other type write off you can rpair and reregister with a few hassles.......Cheers ....Dave
203205
Reply By: 100 Series - Monday, Nov 06, 2006 at 19:39
Viehicle identification numbers (VIN) can not be taken from one vehicle and put onto another as the VIN is unique to each vehicle.
If the vehicle is a staturatory write-off it can not be re-registered, it can only be used for parts.
Repairable write-off can be re-registered once repaired and inspected, however will alwaty appear on the written off register when a search is done.
203392
