3G vs Next G - is there a difference?
Submitted: Friday, Nov 10, 2006 at 11:40
ThreadID: 39306 Views:45215 Replies:11 FollowUps:14
Pardon my ignorance, but is there a difference between these, or are they the same?
Telstra has different coverage maps for each, 3G appears to presently have the same covereage as GSM and Next G appears to roughly equate to CDMA coverage.
I thought the idea was to scrap two seperate networks and have one you-beaut job.
(I have done a search here and not found anything discussing the difference and future of these two systems)
Reply By: stevesub - Friday, Nov 10, 2006 at 11:58
For the user, not a lot except for the better coverage of NextG than 3G which is Telstra's name for 3G. Technically, there are some differences which means you probably cannot use a 3G phone on NextG - ie you need one of Telstra's NextG phones
I hope that their roaming is like GSM but I am not holding my breath or ditching my GSM phone.
Stevesub
AnswerID: 204099
Follow Up By: GaryInOz (Vic) - Friday, Nov 10, 2006 at 17:38
First of all.... NextG and 3G operate on two separate frequency bands 850 Mhz and 1800-1900Mhz respectively). No commonality at all, unless Telstra release a dual band phone. Telstra's official name for 1800-1900Mhz 3G is "I-Mode".
It is like the old analogue and GSM systems all over again.
Roaming from area to area (assuming there is coverage) is no different (ie seamless).
FollowupID: 463907
Reply By: joc45 - Friday, Nov 10, 2006 at 12:44
Hi John,
Next-G replaces CDMA and works in the same band; 850MHz, a bit below the 900Mhz GSM band. It encompases all the 3rd-Generation facilities (video, high-speed data, etc), which CDMA could not. I believe it uses CDM technology, so like CDMA, it's not restricted to the GSM limit of 32km range. In fact I have heard users are getting better range than the CDMA it is replacing.
Since it is sharing the same band as CDMA, as NextG is taken up more, CDMA bases will be gradually shut down over the next 12 months or so. I guess this will mean more congestion for existing CDMA users, generally showing up as poorer performance at its limits (as more users share the same frequency, performance drops off), creating an incentive to swap over to the new techology.
The technology is not interchangeable with 3G.
Gerry
AnswerID: 204107
Follow Up By: Member - Jeff H (QLD) - Friday, Nov 10, 2006 at 17:13
But do a string of Gs constitute a g-string, and will it weally work?
FollowupID: 463888
Reply By: pmacks - Friday, Nov 10, 2006 at 13:22
mmmmmmmm ok
so that means i can still talk as long as the string is tight and attached to the jam tin ? right ?
pmacks
AnswerID: 204113
Follow Up By: Gramps (NSW) - Friday, Nov 10, 2006 at 15:31
Jam tins are being phased out. You'll need Red Bull tins, sorry :)))))
FollowupID: 463857
Follow Up By: jdpatrol - Saturday, Nov 11, 2006 at 11:05
I'm finally starting to understand the whole thing. Thanks guys.
FollowupID: 464017
Reply By: Member -Signman - Friday, Nov 10, 2006 at 14:02
I think 3 (3G) is a network in it's own right- maybe a spin-off from the Orange Network.
G (or Next G) or whatever is the supposed Telstra CDMA replacement.
AnswerID: 204117
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Nov 10, 2006 at 16:23
3G and Next G are quite different frequencies so it isn't a spin off. 3G are restricted to the other networks, their coverage of Australia is much more limited too. Next G is Telstra's name for it's own third generation system hence the term 3G only Next G is more G3.5. It is said to very much extend the range..... Might even become a shareholder again, heaven forbid!
FollowupID: 463869
Follow Up By: joc45 - Friday, Nov 10, 2006 at 19:49
As far as I know, up till now, Telstra's 3G offering has been a tie-up with Hutchison's ("3" network). Telstra never bought any 3G spectrum with the auctions a few years back, sticking with the 850 MHz band they already owned. With the rollout of Next-G, I believe Telstra will be dropping the 3G offering. This appears to have been a clever move, as some telcos paid a fortune for their 3G spectrums and Telstra has had to spend little on 3G infrastructure. As stated on another post here, the Next-G is really "3.5G"; ie, better than 3G. The data rate exceeds by far the opposition's rate, and software is being tested to increase it further. I read somewhere that they are also testing software to extend the range (distance) even further, tho I feel that the radio technology is being pushed to its limits here.
Also, as I understand it, Telstra has already fitted out every CDMA site with Next-G, so the cutover is pretty seamless. Quite a massive undertaking, as it was only early this year it was announced.
BUT, if Next-G is too popular, Telstra may have to purchase more spectrum, most likely in the 2GHz band to augment the limited 850MHz band, just as GSM has flowed over into the 1800MHz band. But the 850MHz band has the inherent advantage of better range, which is most likely why Telstra chose to run with this band.
Probably the main disadvantage with Next-G at present is the limited product range of handsets.
Gerry
FollowupID: 463931
Reply By: Tom.I - Friday, Nov 10, 2006 at 15:36
trying to make it simple....
3g = 3rd generation mobile phones. the handsets have rich text capabilities such as video downloads and mobile TV etc. You need the high speed 3g networks which all carriers now have to download video and music full tracks etc
Next G is Telstra's brand and it is quicker than the other 3g networks. Its a much better experience but being Telstra - you pay for it
AnswerID: 204133
Follow Up By: Member - Crazy Dog (QLD) - Saturday, Nov 11, 2006 at 16:27
Heard a buzz 4G is on the way...
Grrr!!!
FollowupID: 464054
Reply By: Member - Oldplodder (QLD) - Friday, Nov 10, 2006 at 15:45
Son has 3G.
It does not have the same coverage as GSM for all of the 3G facilities.
It only has full facilities for limited areas in the big cities.
It does however drop down to GSM when out of range of 3G for normal GSM type phone use.
I think there is something similar happening with Next G.
Still limited coverage until all CDMA towers converted over.
My church (Uniting Church, Qld Synod) are doing trials at the moment with Next G and keeping interested people in the church posted. Next bulletin in a couple of weeks or so.
AnswerID: 204135
Follow Up By: Member - Oldplodder (QLD) - Friday, Nov 10, 2006 at 16:21
Oops, better put a theologival correction in there. It's not my church, but the one I attend. :o). And no, they are not expecting a better connection to heaven, no matter how well Telstra talk up Next G!!!
FollowupID: 463868
Reply By: StephenF10 - Friday, Nov 10, 2006 at 16:09
They are different networks. The original 3G is 2100mhz and has the same coverage as GSM. NextG is 850mhz and will have the same coverage as the CDMA network it is designed to replace.
Stephen.
AnswerID: 204142
Follow Up By: Truckster (Vic) - Wednesday, Nov 15, 2006 at 16:57
Ill believe it when i see it.
FollowupID: 465095
Reply By: John R (SA) - Friday, Nov 10, 2006 at 17:18
Right. Clear as mud now!!
Thanks everyone for your comments. Next time I drop my phone in a trough, NextG it will be.
It does sound as though there will still be two networks running though.
AnswerID: 204156
Follow Up By: Member - Oldplodder (QLD) - Friday, Nov 10, 2006 at 17:27
I think Telstras great hope is that GSM will also die, and all go to Next G.
Time will tell.
FollowupID: 463899
Follow Up By: joc45 - Friday, Nov 10, 2006 at 19:55
I'll bet they would too, but GSM is still the workhorse technology worldwide (almost - US and a few others excluded), it's relatively cheap, and it's great for international roaming, so I reckon it will be around for a while yet. There are a lot like me who just like to make phone calls and send the occasional SMS. I don't want to broadcast pics of my ugly mug around the world!
But then, if Telstra would drop the prices of their mobile data offerings, then I might be coerced into that technology....
Gerry
FollowupID: 463932
Reply By: Sam from Weipa Auto Electrics - Saturday, Nov 11, 2006 at 08:20
I just purchase 2 next g phones I will see how they go?
AnswerID: 204246
Reply By: Richard & Leonie - Saturday, Nov 11, 2006 at 21:19
I had a Telstra CDMA phone. I was approached by Telstra to update my phone plan and was recommended to change over to 3G. Knowing the the life of CDMA was limited I elected to change over. 6 weeks later they bring out NextG which now I understand will replace CDMA. The Telstra saleswoman did not tell me to wait until the NextG system came out. She quite happily sold me 3G. I complained to Telstra and their attitude is tough luck. If I want to change over to NextG I have to pay a penalty. I have lodged a complaint with the Telecomunications Industry Ombudsman who todate appear to side with Telstra. I do not intend to give up and as a former public servant know how the system works. I live in the country and this is typical of the raw deal people will get from Telstra when fully privatized. My advise is wait until the CDMA system is on it's last legs before you change so you can be sure what ever you change to is the best system. I have been with Telstra (Telecom) for 35 years. I have three mobile phones and a land line. I was about to buy a Satphone. They will loose me as a customer.
Richard
AnswerID: 204323
Follow Up By: phil - Sunday, Nov 12, 2006 at 13:57
An unusually honest Telstra Customer Service person also advised me to hang on to my old CDMA phone as long as possible. Her reasons included the very limited availability of Next G phones at this time. Incidentally they will roam using GSM overseas. Another potential problem for many country usere is the complete non- availability of phones which can use an external antenna.
There will very probably good deals to change over when they really want to move everyone off CDMA in a year or so.
Phil I
FollowupID: 464181
Reply By: GaryInOz (Vic) - Saturday, Nov 11, 2006 at 22:20
Melbourne has a lot more than 3GG's in town at the moment....
Seriously you have to make the distinction between the "tech" 3G, the company "3G" and the "concept" 3G.
AnswerID: 204334
Follow Up By: Rick Smith - Wednesday, Nov 15, 2006 at 12:01
As far as I know the systems are all incompatible - either frequency bands or system/data format. The idea of a "Universal Mobile Telephone System" UMTS has died many time over !! So don't get carried away thinking your CDMA (AUS) will work overseas with anyone else's or GSM or 3G. Some dual band or tri-band phones have it all....... but that's going to change too.
3G referred at one time to any phone faster than 160Kbits, but everyone is aiming higher now - DOCOMO in Japan had the first commercial 3G probably still a few million users there. See what China adopts - they are going to be BIG users.
Next G apears to be a "gadget phone" intended to generate meter clicks and income for Telstra who are hell bent on making you spend as much as possible on a call in as short a time as possible - probably to help pay for their executive salaries !
With video phone and web browsing the data download is going to generate them a huge revenue if mobile users are dumb enough to stay online for hours - it's cool man !!
CDMA and next G are reasonably suitable for long range/urban users as they do at least offer range. The current coverage maps from Telstra are probably vapourware, as Next G is using the same frequency bands and aerials/towers as CDMA - there's only so much to go round ! When CDMA slows, next G will speed up. CDMA was touted to be closing by end 2007, but this may stretch to 2009 as many users will probably not blindly migrate to new "whizzbang" Next G phones - of which there are few anyway.
It's a sorry thing that the old AMPS has died in the country as range and ease of use as well as a lack of bulls@#$ options made it quite practical. Range of 100Km was not impossible and even 150Km from mountaintops.
I've always figured it's the mug on the phone that makes the difference - NOT the handset or the system. That is NOT Telstra's interests however.
I'd wait for CDMA to be struggling before changing, new users usually subsidize any new technology and latecomers get cheaper access for nothing more.
Rick
FollowupID: 465010
Follow Up By: StephenF10 - Wednesday, Nov 15, 2006 at 15:54
Some of the NextG plans look attractive, such as untimed calls on a $55pm plan or 5c/min on a $40pm plan. Another reason to ditch the fixed line.
Stephen.
FollowupID: 465075
