navara brakes again
Submitted: Monday, Nov 13, 2006 at 21:23
westBob
still trying to find a cheap way out of my brake problems...the pipe that runs from the back of the alternator to the booster,can i run it to the inlet manifold instead of the alternater and do away with the pump on the back of the alternator .... just a thought ..Bob cheers
Reply By: Barnray - Monday, Nov 13, 2006 at 21:36
Sorry Bob but a very definate No, there is not enough manifold vaccum to power the brake booster. Barnray
204744
Reply By: runninGU - Monday, Nov 13, 2006 at 21:42
that pump on the back of the alternator is a vacuum pump, usually, i have never seen under the hood of a navara, but why would you want to by-pass this???
204745
Reply By: Bilbo - Monday, Nov 13, 2006 at 22:42
westBob seems to be trying to save horsepower. But what the hell that has to do with improving the braking I'm not sure.
Bilbo
204758
Reply By: Nav 8 - Tuesday, Nov 14, 2006 at 11:33
The vacuum pump at the back of the alternator supplies the vacuum for the brake booster. If the vanes in this pump are worn you will have low vacuum and will in turn affect the brakes. The other reason for low vacuum can be low oil pressure in the engine as the vanes in the pump are forced out to the cylinder wall by the oil pressure. If the vanes are not seating on the wall low vacuum is the result. This used to be a problem in the old Toyota 2H engines and was fixed by an increase in the pressure of the oil pressure relive valve spring, either one could be your problem.. Nav.
204858
Reply By: Redback - Tuesday, Nov 14, 2006 at 12:30
Stop buggerising around with cheap fixes and fix the brakes properly.
No such thing as a cheap fix when it comes too brakes, there important you know!!!!
Baz.
204870
Follow Up By: Truckster (Vic) - Tuesday, Nov 14, 2006 at 17:06
x eleventeen....
why save $1.00 on a brake issue? Fix the bleep in things.
464820
Reply By: Member - Ian W (NSW) - Tuesday, Nov 14, 2006 at 15:53
If you really must dispense with the alternator driven vacuum pump then you can fir an electric vacuum pump available from any good performance
shop.
The doof doof hoon hoon boys usually mount them in the boot. Somewhere between the sixty seven stacker CD Drive and the super dooper sub sub sub woofer and their spare backwards facing baseball cap and crutch down at the ankle baggy shorts.
Ian
204907
