kaymar spare wheel carrier
Submitted: Thursday, Nov 16, 2006 at 14:05
Member - Geoff W (VIC)
Hi all, first time member long time vistor.Ive had a wheel carrier fitted which was loose (the plate where the spare bolts on to the carrier which was letting the spare rock up & down) and was just wondering if any one else has come across this problem? It is a brand new left h/side Kaymar spare wheel carrier fitted by A.R.B Northern & the vehicle is an 80 series.
cheers geoff
Reply By: Longreach - Thursday, Nov 16, 2006 at 14:11
Haven't had that problem. Do you mean there is a lot of free-play in the way the wheel sits on the bolts (3 on
mine) or that the plate doesn't tighten up against the wheel ?
205319
Follow Up By: Member - Geoff W (VIC) - Thursday, Nov 16, 2006 at 14:19
Longreach & thanks for repling, the wheel is tight on the 3 bolts the problem seems to be with the plate that goes through the carrier.
465285
Reply By: Member - Willie , Epping .Syd. - Thursday, Nov 16, 2006 at 14:18
Hi Geoff ,
I have one and have not had any problem .
Willie .
205321
Reply By: Member - Oldplodder (QLD) - Thursday, Nov 16, 2006 at 14:38
Is vibration the problem?
Maybe replace with Nyloc nuts?
205322
Follow Up By: Member - Geoff W (VIC) - Saturday, Nov 18, 2006 at 15:18
Hi Oldplodder,thanx for your reply,the problem is in between carrier housing & the bracket that the spare bolts on to.
cheers.
465585
Reply By: Moose - Thursday, Nov 16, 2006 at 14:44
Take it back to ARB Northern and get them to fix it. Shouldn't be loose.
205323
Reply By: Beast of Bodmin - Friday, Nov 17, 2006 at 19:27
Hi Geoff,
Not wanting to hijack your thread, just a quick query about the cost.
My 80 wheel carrier is a no-brand type with a greasable pivot but no bearing. However 14ys has worn the guts out of it and there's loads of slop.
So Kaymar carrier is on the 'wanted' list.
How much did you pay for the carrier and how much for labour?
BoB
205518
Follow Up By: Member - Geoff W (VIC) - Saturday, Nov 18, 2006 at 15:23
Hi Beast abit over 1200 including labour
465586
Reply By: Member - BBB - Friday, Nov 17, 2006 at 19:55
Geof
Welcome to Exploroz
Hope you get as much out of this as we do we love
camping, traveling and the out doors and you can not get a better site than Exploroz to do your home work it is a great site and community.
To make the most of your member ship put the Photos of your new van and holiday pitchers in the members rig and profile then your
camping photos in the Photo album at the bottom of that page.
Use the Members
Trips and gatherings we have been to two so far and met some good people and had a ball over the week end.
If you want to put the Exploroz sticker or wheel cover on the back of your car or van then other members will come and introduce them selves to you when you are camped.
I dont have a wheel carrier but we are thinking of geting one I priced one from ARB and they want $3800 is this the sort of Money you payed ?
They may be good but are they $3800 good ?
Welcome
BBB
205527
Follow Up By: Member - Graeme (NSW) - Saturday, Nov 18, 2006 at 08:11
BBB
I have got a Strongarm dual wheel carrier on the back of the Patrol. It has roller bearings for the pivots and substantial latches to hold it open and closed. There are hi-lift jack points as
well, and fitted was a lot less than 3 grand. I have been very happy with it.
Graeme
465550
Follow Up By: Gramps (NSW) - Saturday, Nov 18, 2006 at 08:19
$3800 to store a spare wheel !!!!! Glad I can just throw the 'extra' in the back and keep the standard spare as is. Can buy a lot of 'must haves' with that $3800 LOL
465553
Follow Up By: Member - BBB - Saturday, Nov 18, 2006 at 17:55
Graeme
Where do you by the strong arm from I have not seen them at ARB or TJM ?
BBB
465598
Follow Up By: Member - Graeme (NSW) - Sunday, Nov 19, 2006 at 07:29
All Terrain 4x4 in Moorabbin. Sorry I do not have any further details as I am in
Port Augusta and heading to
Leigh Creek.
Graeme
465654
Reply By: Member - Andrew W (SA) - Friday, Nov 17, 2006 at 20:23
I will say that rear wheel carriers cop a hiding as soon as you go off-road.
I have a Kaymar Dual which I think has a similar arm arrangement to yours although it doesn't sound like yours has the problem
mine had.
The "stud plate" is held onto the arm by two 1 inch bolts that screw into it through the stud plate's securing post. The top part of the arm had actually cracked where the bolts go through, on my last simpson trip and had to be reinforced and welded back together.
You might check closely that nothing is breaking.
Andrew.
205530
Follow Up By: Member - Geoff W (VIC) - Saturday, Nov 18, 2006 at 15:35
Hi Andrew thanks for repling (and also all who did aswell) that seems to be where my problem lies, where the stud plate goes through the housing there seems to be between a 5 mm and 10 mm gap. The two securing bolts are tight but the stud plate still rocks withinn the housing(seesaw motion).
Cheers Geoff
465587
Follow Up By: Member - Andrew W (SA) - Saturday, Nov 18, 2006 at 16:01
Well I suggest getting it welded up/tightened up with reinforcing if necessary.
With the fact that it hangs off the back with a rubber stopper, plus in my case the tyre touches the arm so has a slight vibration there (enough to wear off the powder coating) and with a heavy weight suspended on it, it is multiplying the forces with leverage to boot, and thus all you are doing with any looseness is adding momentum and other rotational forces that will serve to break and/or loosen more.
Just lifting the wheel back on is sufficient reminder of how much weight is sitting up on there.
Andrew.
465590
Follow Up By: Member - Geoff W (VIC) - Sunday, Nov 19, 2006 at 01:31
I took it back to ARB & they said they had fixed the issue.What they done was to pull the spare hard up against the carriers arm to stop the movement,when i querried them about this they said its fine.Another concern now is the spare rubbing on the arm & any sand,dirt,rocks etc getting in between the spare & the arm & wrecking the sidewall of the spare, (as we all know its pretty cheap to replace a brand new BFG AT 275 x70 x16)
I also spoke to kaymar as
well and they say its ok as
well but im still not convinced its right.
Any way thanx all who answered & gave advise its heartening to know people are out they with similar interests and are willing to sit down and help a newbie with some wisdom,wisdom comes from experience and experience you can not buy! Cheers all geoff
465649
