Jayco Jockey Wheel
Submitted: Friday, Nov 17, 2006 at 15:27
ThreadID: 39534 Views:2210 Replies:3 FollowUps:0
Hi All, just put a new swing away jockey wheel on the freedom {02}, for sway bar clearance, I've had to set it back a fair bit {nearer the van front} is that O.K. ? cant really see how else it can be done any advice is always good,
regards,
Reply By: Penguin (NSW) - Friday, Nov 17, 2006 at 16:49
Hi Dave
I've seem some vans with the jockey wheel mounted to the inside of the A-frame. Not sure if you'd have the clearance for a swing-away type.
Mike
AnswerID: 205499
Reply By: hoyks - Friday, Nov 17, 2006 at 17:26
I can't see a problem other than it may be a bit heavier to wind it up and down as you have less leaverage.
Inside the A-frame would be good, if you have clearence from brake cables and the sway bars, as then you would be less likely to bash your leg on it.
AnswerID: 205501
Reply By: Dave Thomson - Saturday, Nov 18, 2006 at 16:20
Yes thanks for that guys, unfortunately my backs crook so pulling it from the inside would'nt be good for me {funny position} but I think its safe to say it should be O.K. where it is, but thanks anyhow,
regards,
AnswerID: 205623
