Oil Leak Patrol ZD30 Engine
Submitted: Sunday, Nov 19, 2006 at 21:53
PhilZD30Patrol
Found oil leak when I arrived home tonight from 200kms off road and then hi way trip.
Lots of oil spread on driver’s side from rear of underneath of front diff to cross member near gear box. Many drops on the cross member and many other drops underneath on engine sump etc etc. Floor and chassis covered in oil
Looks as though it is dripping from low down on drivers side engine block
Any suggestions?
Engine oil level is still OK but I am pretty certain it is engine oil.
Reply By: Voxson (Adelaide) - Sunday, Nov 19, 2006 at 22:38
sure its not flingoff from the front uni joint?
have you just had a service?
205834
Reply By: Member - Jiarna (NT) - Sunday, Nov 19, 2006 at 23:38
Maybe a small hole or split in the sump from the off-roading?
Good luck
205840
Reply By: Member - Phil G (SA) - Sunday, Nov 19, 2006 at 23:45
I thought the front engine oil seal is the usual culprit.
205842
Reply By: 3.0turbob - Monday, Nov 20, 2006 at 07:42
Phil,
Hard to say; best thing to do is clean the whole area with a good engine degreaser and then check underneath very regularly to see if you can see a leak. It's common for them to develop a slight leak from the front crank seal area (just above the front of the sump).
Mine has a slight weep in that area, a few drops every couple of weeks. I've never worried about it, nothing a rag won't fix.
The other thing is if you've just had an oil change, the collector/drain box underneath the filter could still be holding a bit of residual oil and this is draining through the drain pipe spitting oil all over the place, but this is on the passengers side.
Hope you find the source,
Rob
205855
Reply By: PhilZD30Patrol - Monday, Nov 20, 2006 at 11:07
Thanks for your replies. I have just dropped it into Mr Nissan.
It is not leaking from the front crankshaft seal or the oil filter drip tray drain.
My guess is that it is the rubber hose on the cylinder head oil return pipe.
205878
