Waeco remote power appliances
Submitted: Thursday, Mar 20, 2003 at 15:29
ThreadID: 3963 Views:2162 Replies:9 FollowUps:6
Iam keen to buy one of these units, but would like to see what people who own think. Have been told that a Thumper will run a CF50 from 12 hours 72 hours, help please. Bruce
Reply By: Member - Nick - Thursday, Mar 20, 2003 at 17:23
OWN A WAECO URBAN POWER SUPPLY & FIND IT REALLY GOOD TO POWER OUR ARB 40L FRIDGE & 12V LIGHT.CARNT TELL YOU HOW LONG IT WILL RUN OUR FRIDGE AS WE HAVENT TRIED RUNNING IT FLAT.A GOOD POINT OF THESE UNITS IS THAT YOU CAN MOVE THEM FROM VEHICLE TO VEHICLE,INTO YOUR TENT FOR LIGHT OR ANYWHERE.I GUESS RUNNING TIME WILL DEPEND ON OUTSIDE TEMP & HOW OFTEN THEY ARE OPENED.
AnswerID: 15699
Follow Up By: Member - Bruce and Anne - Thursday, Mar 20, 2003 at 17:41
Thanks for the reply Nick. I would prefer to buy the Urban than pay the big bucks for the Thumper, but dont want to have to run the motor just to charge the thing up. There all a compromise that the problem. Bruce
FollowupID: 9562
Follow Up By: Russ - Friday, Mar 21, 2003 at 00:16
Bruce, I have a Thumper in the back of my HiLux. Run my 39L Engle, light, shower etc when away camping. Have an in car charging kit and it works pretty well. Have been away for 2-3 weeks at a time, and have had little trouble with it. The biggest variable is the outside temperature, i.e. if hot the fridge will draw some power. I usually run mine on 1 when not driving at this rate with moderate opening and not too hot and also not charging, have had 50 plus hours out of it. The versa light drawers about 1 amph. so will also run for about 50 hours before the battery goes flat.
On one trip we were away for 10 days, used it for lighting and the fridge and didnt charge it on the 240 at all.
I agree with Nicks comments. Not sure about the one that you are talking about though.
I'm pretty happy with mine.
Russ
FollowupID: 9589
Reply By: Member - Nick - Thursday, Mar 20, 2003 at 18:16
BRUCE & ANNE , ONE THING TO REMEMBER , ACCORDING TO THE WEACO WEB SITE IT TAKES 4-5HRS TO RECHARGE THE URBAN FROM FLAT BUT 7-9 HRS TO RECHARGE THE THUMPER.(FROM STD CIGARETTE PLUG)WE DECIDED IT WAS EASIER TO KEEP THE SMALLER (AND CHEAPER) UNIT CHARGED.BUT WE PLAN TO BE TRAVELLING ABOUT 4-5HRS PER DAY THUS KEEPING THE UNIT TOPPED UP. HAPPY TRAVELING
AnswerID: 15708
Reply By: Mick - Thursday, Mar 20, 2003 at 20:22
Bruce and Anne, You can work out mathematically how long the various batteries will last. First you need to know the amp/hour rating of the battery. I have a Projecta jump start unit which has a couple of sockets as well as jump leads. It has a 17amp/hour battery. I use a fluoro which draws less than one amp per hour and therefore I could expect 17 hours and maybe a little more. I also use a CPAP machine which draws 1.1amps. I have used it for 2 nights without charging, running it for about 7 hours each night. I used it for a third night after a drive for an hour or so (the vehicle charges at about 3-4amps.) If a fridge drew 1 amp over a period of an hour (most draw about 3 but operate about 30% of the time) I could expect about 15 hours from it. Just find the rating of the battery, the current required for your fridge (take into account ambient temperatures too) out with the calculator and Bob's your uncle!! Good luck!! .... Are you happy with the Waeco?
AnswerID: 15719
Reply By: shaky - Thursday, Mar 20, 2003 at 21:31
if the fridge draws on average, 1.3 amps per hour, then a 48ah unit should run for about 18 hrs. That's assuming you only discharge the batteries to 50% of charge (known as Depth of Discharge). On the Waeco fridges there is a high / low postion switch. On high, the batteries discharge to 11.5V, on low to 10.5 V. By discharging any more than 11.5V with sealed lead acid batteries, you are reducing the life of your batteries far quicker than necessary.
As to charging, all the battery manufacturers recommend no more than C/10, where C is the capacity of the batteries. So 48ah /10 = 4.8 amp charge rate. If you take out 24 ah, then it should take about 5 hrs to charge.
The other option to purchasing, is to make your own. I've just made two 48 ah packs for about $250ea. The only thing I left out is the jump start ability.
AnswerID: 15731
Follow Up By: Time - Friday, Mar 21, 2003 at 08:37
Shaky
Can you give us the dtails of how you made your own, ie what bits and pieces, their cost and how you put it together?
FollowupID: 9601
Reply By: AK - Friday, Mar 21, 2003 at 08:51
Try making your own
1 x battery box $20
1 x deep cycle battery $140
Couple of hella plugs and Anderson plugs $50
I wired a dual battery system to a Anderson plug to the back of the car. When travelling I place the battery box in the back and connect it to the Anderson plug. The battery box has a small lead on it connected to the battery for that purpose, the lid of the battery box also has 2 x female (fused) hella outlets mounted on top 1 for the fridge and 1 for lights.The box only needs to be connect for charging otherwise it is portable ( make sure you strap the box down). Note if you make your own you can put better and larger capacity batteries in them then the waeco and save$.
AK
AnswerID: 15764
Follow Up By: Phil P - Saturday, Mar 22, 2003 at 10:54
Hi AK,
Are you charging this from the car ?
FollowupID: 9659
Follow Up By: AK - Saturday, Mar 22, 2003 at 11:33
Phil yes I am charging it from the car think of it as a proper dual battery system that is portable.
AK
FollowupID: 9661
Reply By: paul - Friday, Mar 21, 2003 at 10:00
i agree with shaky and AK, after looking at the prices of the power packs they are just way overpriced sealed deep cycled batteries in plastic whiz bang casing. There are sooo many batteries out there that can do the job you want for up to a third of the cost. Follow the above advice, get wire connectors, a soldering iron, some inline fuses, some heavy duty cigarette plugs - though i have abandonded these fickle things and gone for 2 pin Clipsal 24v plugs that provide a much better and secure connection. And you can buy batteries now that can happily take charges way in excess of C10 if you want to pay the money for a battery that also has enough CCA to start your wagon and you can recharge straight off the connections to your main battery in about an hour if so inclined. Or if ability to jump start and run your applicances is your only concern buy a cheap Suupercheap jump start pack and keep it under your seat (recharging once every couple months) and use you battery set up in the back for whatever reason you need it.
AnswerID: 15766
Reply By: GaryInOz - Friday, Mar 21, 2003 at 15:23
If I was going to do the job, and I will be in the not-to-distant future, I would be using Odyssey batteries as they are capable of both deep cycle and starting function while being able to be fully recharged within one hour (NO CURRENT LIMIT, as long as charging voltage within specs) from a normal alternator, and half size/weight of equivalent CCA Lead-acid, 400-500 complete charge-discharge cycles, 8-10 year life, etc. No hassles with spilled acid (compared with Lead-acid, Calcium), good long term charge retention (comared with Calcium).
You may get 72 hours out of a Thumper if you do a trip to the Snowies in August.....
AnswerID: 15785
Reply By: Member - Bruce and Anne - Friday, Mar 21, 2003 at 18:03
Thanks everyone for all the replys and follow ups. Decided to go with building my own, I've priced a few batteries and the Odyssey at $368 & GST for a 75amp a bit expensive, but I imagine very good. Thanks again all Bruce
AnswerID: 15797
Reply By: AK - Saturday, Mar 22, 2003 at 11:37
Bruce & Anne if you want to build your own you can buy a battery box from Supa cheap that is already set up it includes cable, circuit breaker and a battery test function and from memory outlets. Cost was $99 all you need to do is add the battery. I didn't go this option but it may suit your needs.
AK
AnswerID: 15845
Follow Up By: Bruce - Sunday, Mar 23, 2003 at 09:28
AK thanks for the info, will check out Supa cheap. Bruce
FollowupID: 9710
