Airconditioning regassing
Submitted: Tuesday, Nov 21, 2006 at 16:47
ThreadID: 39663 Views:10873 Replies:5 FollowUps:6
Hi all,
Does anyone in Melbourne have any recommendations for vehicle air conditioning regassing? Mine has had the new gas installed about 6 years ago, (with the fluro-green dye) in it, however it is simply doing a lowsy job these days.
Is there a reasonably priced company that can do this, simultaneously checking the system for any leaks?
Reply By: Member - Phantom (WA) - Tuesday, Nov 21, 2006 at 16:58
Hi Cannon,
Whilst I am in Perth, I can offer some advise.
We charge $90.00 for a regas which includes the dye and a recheck in a week or so.
Generally you will find that as they are a sealed unit, any deterioration is caused by a leakage which is not a good sign.
Any automotive dealer or air cond mob would be able to help....just get some quotes first.
Steve
AnswerID: 206145
Follow Up By: Cannon - Tuesday, Nov 21, 2006 at 17:08
Hi Steve, I appreciate the reply.
FollowupID: 466087
Reply By: Ray Bates - Tuesday, Nov 21, 2006 at 17:58
I don't know what gas you have in your air conditioner but if it is an old vehicle the gas is not available and to put the new gas in they want to change all the seals as your existing seals are not compatible. BUT they can install a form of LPG that works very satisfactory at the fraction of the cost
AnswerID: 206156
Follow Up By: Member - Phantom (WA) - Tuesday, Nov 21, 2006 at 18:29
Hi Ray,
If Cannon has had it changed in the past 6 years it would have to be R134A which has been in use since 1988. THe old R12a has been illegal to dispel into the atmosphere since then.
Steve
FollowupID: 466110
Reply By: martz8 - Tuesday, Nov 21, 2006 at 20:17
Viking fleet service in Melbourne Not sure on price though
(03) 9314 7805
Hope this helps
Marty
AnswerID: 206206
Reply By: Member - Stephen M (NSW) - Tuesday, Nov 21, 2006 at 22:31
6 years is a good run. Most air cons will eventually run out of gas as they do seep though the rubber flexi pipes over time. Dont let them suck you into doing flush's and all that crap. Just get a new receiver dryer (filter) put on and a vac out and regas. They changed the gas types between 93/94 so wont be an issue with yours unless the vehicle is older. Also check yourself that there is no crap cought up between the condensor and radiator which will stop air flow but would normally be picked up due to higher vehicle operating temps. Also if vehicle is fitted with electric fan make sure it is operational. All this helps with the air con. Regards Steve M
AnswerID: 206260
Follow Up By: Andrew-rodeo - Wednesday, Nov 22, 2006 at 20:00
I would recommend getting the whole system checked, and it requires the oil to be flushed then it worth getting done. Should only cost about $200 to get a flush and re-gas with R134a.
FollowupID: 466359
Reply By: Angler - Tuesday, Nov 21, 2006 at 23:50
I managed to keep the following bit of trivia from a forum somewhere.
I checked the web site then and the stuff sounded great.
OK it's flamable, funny we carry big mobs of other flamable stuff in tanks and thats OK.???
Hi all,
I bought a bottle of HR12 (www.hychill.com.au), and got a mate to vac
then charge the system.
Now it'l freeze the balls off a brass monkey.
Don't be fooled. World wide figures show that R134a and its
derivatives cause 8 times the compressor failures than R12 did (auto),
but HR12 causes 3 times less failures than R12. (lower pressures,
better oil circulation etc.) this gas is now used in domestic cars and
refrigerators in Germany. They use 134 is for export requirements.
HR12 does NOT CAUSE ANY POLUTION.
It is inflamable as it is a mix of hydrocarbon gasses but I have been
using it for 18 months with no gas loss and briliant cooling no matter
what the outside temperature or humidity. As for the risk of fire, if
the gas was leaking inside the car it would be possible to get a
buildup, however since the gas is heavier than air it would probably
escape via the condensate drain. If the leak was under the bonnet then
the gas would just discipate harmlessly.
Contact Hychill. (They are in Victoria)and they can ship the gas to
you.
Pooley
AnswerID: 206278
Follow Up By: Member - Stephen M (NSW) - Wednesday, Nov 22, 2006 at 20:13
Hi there Pooley, can this be put into the old compresors or the new ones or both. ??? Regards Steve M
FollowupID: 466363
Follow Up By: Andrew-rodeo - Friday, Nov 24, 2006 at 21:58
HyChill (HR12) will go into any system
FollowupID: 466738
Follow Up By: Angler - Saturday, Nov 25, 2006 at 22:22
Stephen,
Dunno mate, I just decided to keep the text for maybe future use.
Check out the web site and maybe mail them.
Pooley
FollowupID: 466874
