landcruiser rims
Submitted: Wednesday, Nov 22, 2006 at 19:23
ThreadID: 39692 Views:9837 Replies:5 FollowUps:4
could anyone help me find info ? i would like to replace split 78 series rims with landcruiser GXL standard rims. will the rims be suitable & not cause problems with steering etc. thanks.
Reply By: Rossco105td - Wednesday, Nov 22, 2006 at 20:56
Hey childos,
I believe the rims will fit, and cause no probs.... the only prob may be finding those rims! Has taken me some time to find good condition GXL steelies 2nd hand at the right price, Toyota wanted $345 per rim, for steel rims!
Rossco.
AnswerID: 206438
Reply By: Bob Y. - Qld - Wednesday, Nov 22, 2006 at 20:59
childos,
You'd need to get the GXL rims cheap, to make it worthwhile.
I bought 6 of new Brazilian made "Sunraysias"(7" x 16") for $100 each, in Winton. From my experience, the GXL rims start to crack after 200K clicks, and leak air. This was from an 80 series, and from advice given off this site, it must be quite common.
If you go the GXL way, would need to be off std wagon.
Hooroo...
AnswerID: 206441
Follow Up By: Peter 2 - Wednesday, Nov 22, 2006 at 21:47
Have to be 100 series rims as they are 5 stud, anything earlier is 6 stud.
79 series are 5 stud.
FollowupID: 466381
Follow Up By: Bob Y. - Qld - Thursday, Nov 23, 2006 at 06:42
Aware of the wheel stud difference, Peter.
Although the post doesn't read well, was commenting that if 80 series wheels crack, then the 100 series ones may well do so, in due course. You warned me of this fact earlier this year..
The "Sunraysias" bought were for a 79 series, not the 80. Put mags on it.
Hooroo...
FollowupID: 466446
Reply By: Member - Phil G (SA) - Wednesday, Nov 22, 2006 at 22:05
Just make sure you get the 100series GXL rims from the Rigid front end (1Hz, and 4.5l) Cruisers:
They have a different offset to the GXL IFS (TD and V8) cruisers which will not fit your 78series:
The Toyota Royale mag wheels for the rigid front LandCruisers also fit the 78series:
The other option I believe is the 16x6.5 inch rims from the RV 100series:
Finally, you can buy either 16x7 or 16x8 sunraysias.
AnswerID: 206466
Reply By: The Rambler( W.A.) - Wednesday, Nov 22, 2006 at 22:32
I don't know how much travel you have done in the rough stuff up North or in rocky terrain but my advice to you would be to stick with the split rims using the right tyres and you will have far less problems with tyres---again only my opinion based on many thousand ks. using splits in the bush.
AnswerID: 206473
Follow Up By: Richard Kovac - Thursday, Nov 23, 2006 at 23:57
Hi Ramber
up for the second set shortly
whats the code (number) of your Hankook's your are runing
Again
I no should have keeped it last time
Richard
FollowupID: 466599
Reply By: childos - Thursday, Nov 23, 2006 at 08:56
thanks for all your help with the rims question.
AnswerID: 206495
Follow Up By: Member - Alex K (NSW) - Thursday, Nov 23, 2006 at 22:20
Childos, i'm selling 4x 16x8 steel rims that'll fit your rig...
Site Link
FollowupID: 466573
