GU 4.8 Petrol/Gas Usage
Submitted: Sunday, Nov 26, 2006 at 21:43
Jimbo
Well after many weeks of looking, and the very much appreciated assistance and advice from Eric, my Ma and Pa have picked up an immaculate GU 4.8.
This question is more about range than cost, as running on LPG it's a bargain no matter how you look at it.
On the first
tank of LPG, with everyone having a drive and putting the boot in to test out how much grunt it has, it delivered 25L/100km. It should settle down to a bit less than this in normal driving.
They are going to tow a 21' van weighing about 2400 kg loaded.
Thoughts from anyone who tows a big van with one of these would be appreciated. Just how far can they expect to travel on 72L of LPG?
Jim
Reply By: adamj1300 - Sunday, Nov 26, 2006 at 22:45
not far
in a late edition of one of the 4wd mags they did a tow test from memory the patrol used 27 or 28 liters per100kms towing 2500kg on petrol so gas just ova 30
so maybe 300kms range?
207023
Reply By: Robin - Monday, Nov 27, 2006 at 08:11
Careful Jimbo - you might get converted !
I use 20 20 rule - 20% more because its gas and roughly 20% with a reasonable load.
So from acredited 17.2lt/100km standard (I assume auto) this is around 21 with gas / no van and 25 with big van.
Are you sure its 72lt gas ? - thought most were 92lt.
If 92 this gives 92/25 = 360km odd.
Congratulations to them - I think they will love it so much they won't care about fuel cost. I just have a bigger petrol
tank to achieve 1000km plus range
Robin Miller
207051
Follow Up By: Jimbo - Monday, Nov 27, 2006 at 09:31
Robin,
Thanks for the feedback. If they can 25 towing the van the range won't be too bad.
My understanding is that the tanks are safety valve limited to 80% of total capacity. Therefore a 90L
tank will have a capacity of 72.
ATB,
Jim.
467038
Follow Up By: Robin - Monday, Nov 27, 2006 at 09:38
Yep pretty hard to find a 90% fill one now, but thats a small
tank , most of fitted ones were bigger to allow for roughly the same actual gas as petrol
tank was.
Robin Miller
467039
Follow Up By: Brew69(SA) - Monday, Nov 27, 2006 at 20:08
My GQ has 115 usable.
467129
Reply By: Member - DOZER- Monday, Nov 27, 2006 at 18:19
A friend at work has had his gas on for a few weeks and is returning 11c/km economy without the van....and stopping every 250kms for gas allows one to take in more of the scenery :)
207158
Follow Up By: Jimbo - Monday, Nov 27, 2006 at 22:06
Fair call Andrew
467159
