Auto aerial replacement GQ
Submitted: Monday, Nov 27, 2006 at 23:54
ThreadID: 39841 Views:2272 Replies:7 FollowUps:1
Broke the aerial (normal radio) on the 93 gq!Is there a after market job or do I need to visit my expensive Nissan dealer.I have been to super cheap and they have a replacement with the same Diameter 11mm base but not sure of the tail length Ect.Any experience of this out there.Thanks in advance.
Niffty Perth
Reply By: donks1 - Tuesday, Nov 28, 2006 at 07:31
$60 for the manual
$85 for the electric
doesn't seem that bad to me
AnswerID: 207258
Reply By: Nick R - Tuesday, Nov 28, 2006 at 09:14
or $14.95 for a rubber aeria these don't break in a hurry
NickRl
Carpe Cerevisi
AnswerID: 207271
Reply By: 666toy - Tuesday, Nov 28, 2006 at 09:53
supercheap,repco,autopro I think they will fit most vehicles .
AnswerID: 207283
Reply By: Member -Signman - Tuesday, Nov 28, 2006 at 12:04
If you do a bit of bush work- and forget to retract the antenna - why not a stainless steel springy type one as fitted standard to late model Jackaroos.
Can't break em.
Should be able to get one as a non-genuine part.
AnswerID: 207300
Reply By: Member - BUNDY BOY (WA) - Tuesday, Nov 28, 2006 at 16:43
Niffty.......had the same prob.....and no...the after market retracables don't fit .as there's not enough room for there motor placement under the guard........easy to get heavy duty spring base model...to go in the hole....or bracket eg:same as cb style to come out beside bonnet........genuine are way to expensive
AnswerID: 207350
Reply By: kev.h - Tuesday, Nov 28, 2006 at 17:59
The centre aerial with the nylon tail from a commodore about VN modle fits
Undo the nut around the aerial -turn the radio on the aerial will feed out take note which side the teeth are on - feed the new one in turn the radio off push down on nylon section until it catches when it auto stops refit the nut run it up and down a few times until it fully retracts - the commodore one will stay up about 40mm when retracted but for under $20.00 i can live with that
Regards Kev
P.S if the nylon is broken thats easy too, lets know if you need more info
AnswerID: 207361
Follow Up By: Niffty - Tuesday, Nov 28, 2006 at 21:45
Thanks Kev
I will go for this option first.I have only the plastic tail protruding from the aeial base with about 25 mm of the original aerial left.I have a mate that has done his comode aerial, so it sounds like a few beers and its fixed.
Thanks to all for your input.
Niffty
Perth
FollowupID: 467337
Reply By: kiwicol - Thursday, Nov 30, 2006 at 17:11
there is a kit that replaces the aerial and plastc centre $35 fixed my GQ Col
AnswerID: 207794
