coolant alarm
Submitted: Tuesday, Nov 28, 2006 at 08:12
4x4Mad
have searched !! looking to see which coolant alarm is the way to go !
the one that goes in the radiator hose or the one in the coolant resevoir ! who has what ? how do they work ? easy to install ?
Reply By: Member - Craig D (SA) - Tuesday, Nov 28, 2006 at 08:24
Hi 4x4Mad,
I have the Engine Saver that is advertised on ExploreOz, the one that has the probe that goes in the radiator hose. It was very easy to install and gives great peace of mind. I mounted the piezo alarm under the dash in the fuse panel (nice and loud still and out of the way) and the LED (very
bright I might add) to a switch blank to the right of the steering column which is easily visible even in
bright sunlight. This particular unit runs it's own self test at every engine start-up so you always know that it's working. Hope this helps.
207266
Follow Up By: Willem - Tuesday, Nov 28, 2006 at 12:12
Yep I have the Engine Saver as
Mine is super sensitive and I have installed a cut out switch for the alarm so if it annoys me I can turn it off :-) (Just have to remember to turn it on again)
467222
Reply By: 666toy - Tuesday, Nov 28, 2006 at 09:48
As above mate , the ones mounted on the coolant bottle work BUT with a sudden coolant loss sometimes there can be coolant still in the coolant overflow (depending on vehicle ) but none in the radiator itself so a unit mounted in the radiator hose guarantee's to let you know before the ones mounted in a coolant reservoir. hope this helps...666toy
207281
Reply By: Member - Reiner G (QLD) 4124 - Tuesday, Nov 28, 2006 at 10:16
I drive landcruisers for nearly 30 years and never had a problem loosing all my
water in one hit. I do keep an eye on the hoses and when my waterpump died I could smell the coolant within 10 seconds. Not knocking a product just not sure if a coolant alarm is the way to go. After that you need an another alarm to go off when the fuse for the coolant alarm blows........don't know.
Reiner
207287
Follow Up By: 666toy - Tuesday, Nov 28, 2006 at 12:19
G day
just for the record i have been around heavy trucks & machines for a long time & have seen numerous engines saved because of these set-ups but they are not a replacement for general eng maintenance & daily checks but better to have one than not in my opinion . cant do any harm ...666toy
467223
Follow Up By: Member - andrew B (Kununurra) - Tuesday, Nov 28, 2006 at 13:33
Gday Reiner
I've only had it happen once, about $7000.00 and a huge inconvienience, I will always have one in my vehicles for the rest of my life, very cheap insurance, both for the vehicle and its ocupants in a remote location. Still bemuses me that many modern cars have them on the winshield washer bottle to tell you you need to fill it up, but not on the coolant!
Cheers Andrew
467234
Follow Up By: Richard Kovac - Wednesday, Nov 29, 2006 at 00:04
Reiner G
Hi I would agree
Loss of coolant is too late
pressure switch fitted to the coolant system is a better system
Richard
467376
Follow Up By: Member - Doug T (W.A) - Wednesday, Nov 29, 2006 at 01:12
andrew B
Your Right ,seems a bit silly but when thought about if you tell people about these things how you gonna sell new replacement motors if no one needs one [ theory]
I have the Engine saver and soon as the
water level is about an inch down off it goes ,
well worth the money and it's not made in China
467391
Reply By: 4x4Mad - Tuesday, Nov 28, 2006 at 16:33
thanks for all the replys ! going to go with the engine saver advertised here on eo , sounds like all i need to do the job !! thanks again
207347
