New MyRig page for members
Submitted: Wednesday, Nov 29, 2006 at 16:00
ThreadID: 39889 Views:2676 Replies:3 FollowUps:15
Hi Members,
I have just finalised the first of the new image uploader controls. This new control should accept any size image you throw at it. I have only released this currently in the Members My Home - My Rig page so if you can please test the uploader and report any problems.
NOTE: You can change the image description at any time and this will not effect the image loaded in the system.
NOTE: The image system on ExplorOz will now only support output of jpg images so animated gifs will be transformed into static jpg. If you have an animated gif image then please do not go into the My Rig page as the system will transfer as soon as you load the page.
NOTE: You can upload any supported image format .png, .gif, .jpg and the system will do the required conversions.
NOTE: If you resize your image down before upload it will make the transfer faster. The My Rig system now uses images up to a max dimensions of 800 pixels.
Good luck and let me know of any problems
BTW: I have not updated all the associated pages that display the Rig pics yet however this will be starting soon so you may only see smaller images on some screens until I have completed the remainder of the updates.
Reply By: Brew69(SA) - Wednesday, Nov 29, 2006 at 16:42
Testing
AnswerID: 207576
Follow Up By: Member - Beatit (QLD) - Wednesday, Nov 29, 2006 at 16:48
Still looks the same! Still looks good even in small print.
FollowupID: 467494
Follow Up By: ExplorOz Team - David - Wednesday, Nov 29, 2006 at 17:01
Just updated the forum to use a new utility that will now enlarge the Rig1 pic directly when you click on it. So to view the Rig & Profile page you need to click on the link called Members Rig & Profile.
It is a subtle change however makes much better use of system resources and will allow for larger pop up views of the pictures. It also fixes the errors created during file transfer that we had in the past.
Thanks for trying it all out - It will only get better from here.
FollowupID: 467495
Follow Up By: ExplorOz Team - David - Wednesday, Nov 29, 2006 at 17:04
I just noticed guys that you do not have a description attached to your image - is this on purpose or was there an error when you updated the images. You can add the description without re-loading the image now so please just add one of maybe where the image was taken or something..... If it was a problem/error then please let me know.
FollowupID: 467496
Follow Up By: Member - Beatit (QLD) - Wednesday, Nov 29, 2006 at 17:16
Sorry David,
I've not reloaded mine as yet. A computer problem, dam USB port isn't functioning. I have descriptions on my images but don't on this one for some reason - maybe this was not available or obvious when I loaded it.
Kind regards
FollowupID: 467498
Follow Up By: Brew69(SA) - Wednesday, Nov 29, 2006 at 17:17
Ok done it
FollowupID: 467499
Follow Up By: Member - Errol (York WA) - Wednesday, Nov 29, 2006 at 21:49
David , i've tryed to put captions on befor with no success . What am i doing wrong ? Errol
FollowupID: 467561
Follow Up By: ExplorOz Team - David - Thursday, Nov 30, 2006 at 13:14
Errol,
You need to go into My Home - My Rig - I noticed you have not done this yet as the image has not updated to the new code. Just go to this page and type the descriptions in the box near the end of the page.
FollowupID: 467662
Follow Up By: Member - Pesty (SA) - Thursday, Nov 30, 2006 at 15:11
How come your rig pic doesnt show the snatch strap attached to the toyota to make it up that sandhill in Oodna brew???
FollowupID: 467683
Follow Up By: Brew69(SA) - Thursday, Nov 30, 2006 at 15:30
That was the hill that the 60 and the prado didn't get up first try lol
FollowupID: 467686
Follow Up By: Member - Pesty (SA) - Thursday, Nov 30, 2006 at 15:34
Bollock's, you must be getting old, your memory is fading !!!LOL
FollowupID: 467687
Reply By: Willem - Wednesday, Nov 29, 2006 at 19:39
David
It works but on dial-up it is a tad slow. I will stick to the old true and tried method by resizing the pics first.
AnswerID: 207608
Follow Up By: ExplorOz Team - David - Wednesday, Nov 29, 2006 at 19:42
Yes it is slow and the reason I mentioned to resize to 800 max if you are able to do so prior to upload. Thanks for the testing Willem and nice pic did it last long? I would not have thought it would have worked at all!
FollowupID: 467526
Follow Up By: Willem - Wednesday, Nov 29, 2006 at 19:56
The plugs only worked for a very short time as the cut became bigger. So the tyre has been discarded with around 20,000km of wear on it.
FollowupID: 467529
Follow Up By: Brew69(SA) - Wednesday, Nov 29, 2006 at 20:10
1 second for me :))
FollowupID: 467535
Reply By: Member - Jiarna (NT) - Wednesday, Nov 29, 2006 at 22:23
Hi David
I tried to change my rig pic, but it wouldn't replace pic 1 with a new pic. So I deleted pic 1, now it still won't load new pic - so I guess I don't have a rig pic now, unless it's a problem with the server? I tried resizing first, but no good either.
AnswerID: 207656
Follow Up By: ExplorOz Team - David - Thursday, Nov 30, 2006 at 13:20
John,
Not sure what happened with this on - the database says there should be an image however it does not exist. I removed the database field so the record is again cleaned up - please try reloading your pic1 again. Your Pic2 is fine so I am not sure what happened. Let me know if you have any more problems with this.
FollowupID: 467664
Follow Up By: Member - Jiarna (NT) - Friday, Dec 01, 2006 at 14:33
Hi David
It worked that time. Maybe I should have deleted the old pic before trying to upload a new one?
FollowupID: 467888
