Site Search
Section Image
Will it run it?
Submitted: Saturday, Dec 02, 2006 at 20:21
Member - Ozdyssey (QLD)
I have been told the Honda 2.0 will run the 'Dometic' caravan air con with no problems.
I have read somewhere the start up watts can be as high as 4500watts. So with the Honda being 2000watts I am having some doubts what its peak is.
or is it not that simple?
Do I need an invertor to make up for the watts on start up.
Does anyone have this particular model of air con and uses a Honda 2.
Click Image to Enlarge
Advertisement
ThreadID: 40000 Replies: 4
Views: 922 FollowUps: 3
AnswerID: 208235   Submitted: Saturday, Dec 02, 2006 at 20:38
ZukScooterX90 (QLD)Member replied:
John,i went through this about 12mths ago,although i am not sure what brand my aircon is i think it maybe the same.Anyway so to be sure there were not going to be a issue i bought the larger Kipor the 3 with the inverter i have not been able to use it while away as of yet but i have tried it at home & runs it without any hassels.If you can borow or hire one of the Honda's to try before you buy would be a good idea.If you can get hold of one then crank it up (the aircon) to max for an hour or even half an hour to see how it go's.Good luck with it.:o))
Bob.
BlueOval F250 7.3 Deisel.
I was born Free. 'That's as good as it's got.'
Reply 1 of 4
AnswerID: 208241   Submitted: Saturday, Dec 02, 2006 at 21:03
Derek from Affordable Batteries & Radiators replied:
H Ozdyssey
I have the Honda eu2.0 and it runs my Heron 2.2 and have no problems.
Here are the specs...
General Specifications
Heron 2.2
Electrical Rating (single phase) 240V, 50Hz
Nominal cooling capacity 2.7kW
Nominal heating capacity* 1.5kW
Maximum rated current - cooling 4.0A
Maximum rated current - heating 6.5A
Maximum L/R current 20A
Maximum air delivery 110 l/s
Installed weight 34kg
* for Heron 2.2 this is delivered heating output
Not sure of the Dometic specs.
Derek.
ABR - SIDEWINDERABR - SIDEWINDER
Business Member: My Profile
Reply 2 of 4
FollowupID: 468222   Submitted: Sunday, Dec 03, 2006 at 09:30
Rob posted:
Hi Derek,
Are you able to run your Honda eu2.0 and Heron 2.2 with the eco throttle switched on?
In my case (with the same setup), unless the generator is running full throttle, the Honda cant "spool" up quick enough to meet the startup power requirement of the Heron 2.2, it goes into overload protection mode.
Thanks,
Rob
FollowUp 1 of 2
FollowupID: 468228   Submitted: Sunday, Dec 03, 2006 at 10:26
Derek from Affordable Batteries & Radiators posted:
Hi Rob,
I run the Honda on normal mode. It has cut out once or twice when on eco so now when I run the a/c I leave it on normal.
Derek.
FollowUp 2 of 2
AnswerID: 208255   Submitted: Saturday, Dec 02, 2006 at 22:32
Motherhen replied:
Hi John - i have replied again on the caravaner's.
Near the Stuart Highway NT
Home to reality - The dream trip is over
Reply 3 of 4
FollowupID: 468209   Submitted: Sunday, Dec 03, 2006 at 06:26
Member - Ozdyssey (QLD) posted:
thks MH
AnswerID: 208382   Submitted: Sunday, Dec 03, 2006 at 19:36
Member - JohnR (Vic)&Moses replied:
John, have a Dometic B1900S and it is powered quite well with a Honda EU20i on eco throttle. I understand that the manufacturer will only provide the guarantee with the Honda unit for stability and surge. The Honda was charging the battery at the time too and running the fridge. :-0
I don't know what the starting current requirement is to compare.
On the way to Gemtree
Who?
Multi famam, conscientiam pauci verentur
Reply 4 of 4
Activities Index
Ripple Manicure and Pedicure Ripple Manicure and Pedicure
Gold Coast - QLD
Why not treat yourself to an express manicure and pedicure to make your nails look gorgeous!
Breakfast with the Koalas for 10 Breakfast with the Koalas for 10
Sydney - NSW
Your adventure begins at 7.
V8 Race Buggies Extreme Drive Package - Gold Coast V8 Race Buggies Extreme Drive Package - Gold
Gold Coast - QLD
Experience the raw power of off road racing for your adrenalin boost in the Gold Coast.
Lotus Exige Hot Laps Lotus Exige Hot Laps
Brisbane - QLD
Lotus are renowned for building some of the best handling cars in the world, strap into the passenge
Book Now - Things To Do
