AC/DC Fridge
Submitted: Monday, Dec 11, 2006 at 22:02
Robsie
Please explain the difference between AC and DC on my fridge. When plugged in to a household power point what do I have the fridge on.
Reply By: disco1942 - Monday, Dec 11, 2006 at 22:15
What type of fridge are you referring to - a caravan 3 way type? If it is one of those then the AC will refer to 240V AC and the DC will refer to 12V DC.
Please give more info like make and model when asking questions - the person will have more confidence in replying an there is less room for an incorrect answer. I just hope
mine is correct.
209873
Reply By: ZukScooterX90 (QLD)Member - Monday, Dec 11, 2006 at 22:21
Robsie,AC (alternat current)240v. DC (direct current) 12v. So when you plug into house hold AC. AC is also known as shore power.:o)))
Bob.
209875
Reply By: Robsie - Monday, Dec 11, 2006 at 22:23
Thanks for the info - just new at this caravanning thing.
The fridge is a 3 way Electrolux.
209877
Follow Up By: Member - Stephen M (NSW) - Monday, Dec 11, 2006 at 22:46
Hi there Robsie, also if you want to reply to someone direct you can do a post follow up so that your answer will be emailed back to them otherwise unless that person that has given you the info looks back on this page again they wont know. Eg Disco 1942 has requested more info so you need to click on his post follow up so he can help you out. Unless now he looks at this post again he wont know you have replied. Just helping you out here as you said you are new so will help you get the answers your looking for thats all. Regards Steve M
469922
Reply By: Neil & Pauline - Tuesday, Dec 12, 2006 at 10:38
AC DC could also refer to the participants in the Mardi Gra.
Neil
209930
Follow Up By: ZukScooterX90 (QLD)Member - Tuesday, Dec 12, 2006 at 21:40
Neil,they could also be......AC(active c.nt.),DC (dead cu..ts):o))) Lolittle.
Bob.
470056
Reply By: Member No 1- Tuesday, Dec 12, 2006 at 13:18
simple really
does not matter what type of fridge...3 way electrolux or engel waeco..its all the same...when you plug it into 240 its on 240...when you plub it into 12vdc itson 12vdc......
now, if your household is anything else but 240v, then i have no idea
209954
