barn door sqeaks in 80 series
Submitted: Sunday, Sep 02, 2001 at 00:00
ThreadID: 403 Views:2486 Replies:3 FollowUps:3
has anyone out there overcome the battle with with rear barn door sqeaks on a standard 80 series?i have tried dry lube tape and adjusting and they all fix it for a short time .just when u think its right they start again,thanks in advance,,,, Ian
Reply By: Steve - Monday, Sep 03, 2001 at 00:00
Had the same pesky noise for ages and got real mad and poured oil/ WD 40 down the inside of the r.h. door using the locking rods to feed it down and it disappeared for a long time, and i just keep giving it a dose when it re-appears!
amazing after I had spent so much time and agro looking to fix this really annoying squeek/rattle!
steve
AnswerID: 1009
Follow Up By: Ian - Monday, Sep 03, 2001 at 00:00
thanks steve,am willing to try anything !!!!!
FollowupID: 290
Reply By: Greg Harewood - Wednesday, Sep 05, 2001 at 00:00
Your prayers have been answered (quite a while ago actually) - found this info on the 8O series owners website - "The two wonder ingeredients to toyota's cure for squeaky back barn doors are :
Parts numbers: 69350-60061 and 69470-60010
They are a new plastic coated lock mechanism and a new catch for the rear barn doors. (Can't remember which one's which but !) Look like they should be pretty easy to install - not real cheap though The catch is about $20 (au) and the lock mechanism is about $60 (au)"
I have no idea if they work - worth a try I suppose - I use to stick bits of cardboard everywhere! (I dont have an 80 anymore)- Cheers Greg
AnswerID: 1031
By the way the 80 series owners website is here
http://www.safari4x4.com.au/80scool/
AnswerID: 1032
Follow Up By: Ian - Thursday, Sep 06, 2001 at 00:00
thanks greg i will look it up
FollowupID: 295
Follow Up By: Steve - Monday, Sep 10, 2001 at 00:00
Ian -- how did you go -- get the problem fixed??
steve
FollowupID: 299
