100 series gearboxes
Submitted: Wednesday, Dec 13, 2006 at 18:59
ThreadID: 40330 Views:3549 Replies:7 FollowUps:3
Hi All
Just read a recent post re -151F & 150F gearboxes in the 100 series cruisers
Can anyone tell me where the weak link is in the 151 series boxes?
I have one so I'm interested to know
Thanks Diesel
Reply By: Outnabout David (SA) - Wednesday, Dec 13, 2006 at 19:01
Not so much a week link. It is just that they are lighter duty gearboxs in the non Turbo models and very similar to the Prado gearbox
AnswerID: 210207
Reply By: luch - Wednesday, Dec 13, 2006 at 19:42
If you have a 100 series
you will have the R151F
Where as the 78, 79 series and factory Turbo Diesel 100 series have the H151F gear box which is more heavy duty
AnswerID: 210211
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 13, 2006 at 20:29
Not quite, any nomally aspirated diesel 78, 79 or 100 Series receives the R150F gear bag.
Factory turbo diesels and petrols receive the heavier duty H151F.
Geoff
Geoff,
FollowupID: 470205
Reply By: Member - Mike_L (SA) - Wednesday, Dec 13, 2006 at 20:23
Prados with the 1kz-te engine have the R150F gearbox, as do Hiluxs and Prados with the new 1kd-ftv common rail motors.
Mick.
AnswerID: 210217
Reply By: ross - Thursday, Dec 14, 2006 at 00:47
I asked a gearbox mechanic the same question and he replied ,the synchroes ,the retainers and the bearings,basically everywhere.
I think you have to fit a bigger flywheel off a turbo to accept the larger clutch if you wanted to change gearboxes
AnswerID: 210288
Reply By: Member - Phillip S (WA) - Thursday, Dec 14, 2006 at 02:04
Hi diesel...I have a 99 landcruiser with the above gearbox and at 120,000 k's thereabouts the fifth gear went....It got stuck in and would not come out.
When we pulled the gearbox apart the short shaft, which comes in two parts, that connects the gearbox to the transfer box, had a stripped spline as well, was just hanging on.( once it goes you lose all drive)
Well the fifth gear part was completely stuffed and so was the output shaft....and it was cheaper to replace the gearbox $3300 and a new beefed up output shaft, 2 pieces, $350, all with 20000 waranty and it is still going strong.
Regards Phil
AnswerID: 210290
Reply By: cowpat - Thursday, Dec 14, 2006 at 08:19
Yeah, there's no weak link. It's all built to the same standard throughout. But it's too small is the problem.
The R151F is the same box used in the Hilux and in the Supra. What do these cars weigh compared to 100 series? The compromise is probably based on engine power as the N/A's are not very powerful and might be perfectly valid if most of your use is on the bitumen but in my opinion fails miserably when we're talking about the constant load due to pushing 3+ tonnes over corrugations for days at a time...
Weak points? Input bearing, output shaft (early 7X series models), synchro rings, lack of synchro on reverse (a bit of metal comes off every time you engage it if there's any movement), no forced lubrication (no oil pump and therefore no filter screen either) means it just won't last as long... Casper
AnswerID: 210298
Follow Up By: dieselup - Thursday, Dec 14, 2006 at 21:52
Thanks for the info everyone
Looks like I'll just keep changing the oil every 10k and see how we go
Cheers Diesel
FollowupID: 470399
Reply By: Johnny boy - Friday, Dec 15, 2006 at 16:15
Mine went bang at about 200,000 km 4th and 5th share the same selector hub and mine was cracked in three places so I bought a new selector hub 5th gear and put a kit threw it also machined flywheel new daiken clutch and PP and bearing mate of mine put it all back together and I reinstalled it all for about $1200 thanx to DON KYATT seven hills done over 25,000km still going strong !!
I think my post was 29945
Regards J,B
AnswerID: 210505
Follow Up By: dieselup - Sunday, Dec 17, 2006 at 07:23
Iwas talking to a reputable 4wd suplier yesterday and he told me that there are some updated parts available through Toyota for these boxes
Didn't have time to get the full story , when I do I'll put up another post
FollowupID: 470768
