nissan patrol gearbox
Submitted: Friday, Dec 15, 2006 at 11:12
p0s
My Nissan patrol is not an easy change from 1st to 2 nd and second to 3rd isnt great either anyone have any advice?it's an 02 model 4.8 petrol 5 speed ive owned it for about 6 weeks and is it covered by warrenty?
Reply By: tomjones83 - Friday, Dec 15, 2006 at 11:16
dont know what it would be dude,
mine is the 4.8 auto. very tough gearbox. Maybe your clutch is getting funny, how many klms?
You will be covered by a 3 month statutory warranty if you purchased it from a dealer. other than that, regrettably, no.
210468
Follow Up By: tomjones83 - Friday, Dec 15, 2006 at 11:56
Sorry, the 3 month Stat warranty applies in QLD. Not sure on the other states.
470497
Follow Up By: Marn - Saturday, Dec 16, 2006 at 00:00
If the car is under 10 years old then it applies in nsw too
470622
Reply By: Notso - Friday, Dec 15, 2006 at 11:22
Has the gearbox been rebuilt?
If it has, when they did
mine there was some problem in the way they installed the selectors and it eventually had to be pulled out and fixed.
210469
Reply By: Member - Ed. C. (QLD) - Friday, Dec 15, 2006 at 12:12
Only when cold?? Does it improve when the 'box warms up??
Incorrect oil will give the symptoms you describe..
Nissan specify 75w-90 API GL4... Note the GL4 spec..
I'm using F u c h s Titan 7590, and have no such symptoms..
Regards, Ed. C
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
210471
Reply By: p0s - Friday, Dec 15, 2006 at 12:20
thanks for the reply's , we bought a 3 year warranty with it , it's done 113 thousand km and sometimes it's ok if you change gears slowly , like really slowly .How long would the gearbox last?If you have any ideas please let me know and i dont think it has been rebuilt .
210473
Follow Up By: banjodog - Friday, Dec 15, 2006 at 12:57
A quick check / fix would be to drain the transmission oil and fill it with an 80/90 grade - gearbox and transfer case. Doesn't matter at this stage what brand you use - if it was the heavier 75/140 it may give you the symptoms you've mentioned.
If the change of oil fixed it, then it's all good. If it didn't then at least you know you have the right grade of oil then it could be say the synchros that are worn - just take it from there with the dealer.
470508
Reply By: p0s - Friday, Dec 15, 2006 at 13:11
awesome thanks very much ill give it a go :~)
210479
Reply By: nowimnumberone - Friday, Dec 15, 2006 at 18:20
sounds ike synchros
210527
Reply By: Member - Bucky (VIC) - Saturday, Dec 16, 2006 at 07:17
Had a Rodeo once, that was almost impossible to affect any gear change, when cold.
Happened immediately after a service, and the service manager told me to take off in 3 rd and when it warmed up it would be fine ,,he was right,,bit hard on the clutch though.
I had to wait for the correct oil to be replaced, and in the mean time, I put slippery diff oil in it,,, try that it makes a world of difference !
Bucky
210617
