Oil pressure switch location
Submitted: Wednesday, Dec 20, 2006 at 11:52
ThreadID: 40514 Views:6185 Replies:8 FollowUps:5
I am hoping someone can help me. Have just installed my HF radio in a new 2006 T/D L.C. Sahara. I have used very heavy duty earth straps connected to the chasis from the S/T aerial and also the HF radio box. I am still getting quite a lot of static type electricity crackling noise on all frequencies. The intensity reduces with the motor reduction in revs. The noise is completely gone with the motor switched off. I have been advised that it may be caused by the Oil Pressure switch and to disconnect it. Not being very mechanically minded with new cars, I don't have a clue where to look for this switch. If any one has other information how I can eliminate thie noise I would appreciate your advise, preferrably from some one with a similar car. Thank you and a merry X-mas to all
Reply By: gav99x - Wednesday, Dec 20, 2006 at 13:08
I had the same problem when I connected my Ipod to my radio when it was connected to it's 12V charger (slightly less technical than a HF radio I know but anyway).
An informed person told me that the problem was occurring because of a ground loop problem. Basically if you connect two 12V audio sources to the same battery, there is a difference of resistance between them and the differential current flows between them, causing the static.
I was told to buy a ground loop isolator from Jaycar (about $20) and install it on the connection between the two sources. In my case the installation was on the audio line between the Ipod and the car radio. This solved the problem perfectly.
Do you have the HF radio set hooked up to the car stereo to use it's speakers etc., or something similar? If so a ground loop isolator should solve the problem.
AnswerID: 211351
Follow Up By: Member - George (WA) - Wednesday, Dec 20, 2006 at 13:41
Thanks gav, My HF radio is connected directly to the battery + & - posts with heavy duty cables. The HF radio has it's own speaker connection, independant of ant car radio or stereo equipment/speakers
FollowupID: 471415
Reply By: pepper2 - Wednesday, Dec 20, 2006 at 14:46
George i believe connecting the negative wire from the radio direct to the battery is dangerous may cause destruction of the radio in certain situation others will expand on this
AnswerID: 211367
Follow Up By: Member - George (WA) - Wednesday, Dec 20, 2006 at 17:53
Hi pepper2, Barrett Communications reccommended direct + & - connection to the battery. have had connected like that in the previous car for 8 years without a problem.
FollowupID: 471461
Reply By: BenSpoon - Wednesday, Dec 20, 2006 at 14:51
I get the same with mine. When I run a fluoro, backlight on the GPS or the waeco the problem gets even worse. I also have the HF straight off the battery posts. I have been told it is the earth of the antenna and that this needs to be improved.
I have HF off the 2nd battery and all the other things off the 1st, and there is no link between the batteries when the car is turned off, so it seems like it is not coming through wiring but something else. I am told you can get noise reducers/RF chokes and similar stuff from electronics stores but havent yet. Let us know if you find the cause or the fix.
AnswerID: 211369
Reply By: joc45 - Wednesday, Dec 20, 2006 at 15:20
Hi George,
I believe that the 4.2 T/D Cruisers are bad for HF interference due to the EMI from the electronic injection.
Can be particularly difficult to fix, I'm told.
Gerry
AnswerID: 211372
Follow Up By: Member - George (WA) - Wednesday, Dec 20, 2006 at 17:50
I am inclined to go along with the theory from Ron George and Joc45. There is probably no easy solution, if at all, to eliminate the HF interference in these model cars. I have disconnected the aerial at the unit and no HF interference at all with the motor running. Reconnected at the unit and disconnected at the lead-in and aerial connection under the bonnet, again no noise with motor running. This then brings me to the conclusion that all HF interference is picked up by the self tuning aerial. Have spoken to Barrett Communications, they also have no solution to the problem in this particular series L/C. If any one has a solution please let me know
FollowupID: 471460
Follow Up By: joc45 - Wednesday, Dec 20, 2006 at 17:55
Yep, I think Toyota's accessory to fix this problem is a satphone....
FollowupID: 471462
Reply By: Ron George - Wednesday, Dec 20, 2006 at 17:25
G/day George, mate the advice about disconnecting the oil pressure switch sounds a bit dodgy to me... not for the electrical interference prob. How ya gunna know your oil pressure??? unless, you are going to fit a manual gauge. I can`t imagine a little old pressure switch being the prob, but then again stranger things have happened, I`m more inclined to go with joc45 on this one though, RF interference is a fact of life, remember the good old days when all one had to worry about was the dizzy & alternator for RF feedback... not so now!!! bloody electronic everything, I`m stickin with me old 80 Effie... least I know what makes her tick. Cheers RG.
AnswerID: 211390
Reply By: Member - Phil G (SA) - Wednesday, Dec 20, 2006 at 20:04
My truck also runs the 1HD-FTE motor. I've had the same problem even though my Barrett 950 is installed by the book. I used multiple solutions:
#1 I was advised 2 years ago that any unearthed part of the vehicle needs to be earthed - I went around with a multimeter and put ended up putting earth leads on the exhaust and both fuel tank covers.
#2 I also have big earth leads going from the autotune antenna to the canopy and to the tray and the chassis.
#3 Still had enough noise to stop me using it in the vehicle, and bought a noise reducing speaker from Electric Bug. Cost over $300, but it has multiple settings - I find the first setting works very well - cuts the background noise nicely when driving, and around camp it cuts out lots of extra unwanted noise.
I am happy with this solution even though it cost $$$.
AnswerID: 211418
Reply By: obee - Wednesday, Dec 20, 2006 at 20:51
I had the prob years ago with my amateur hf radio. I had the antenna on the frnt of the vehicle where all the noise was and I fixed the prob by moving it to a well earthed position at the rear.
The radio case should be earthed as should the antenna. The outer of the co-ax is the bit that needs earthing of course. The vehicle becomes the ground for the signal. I trust you are using 50 ohm co-ax otherwise big probs.
Oh, dont touch the oil pressure switch; what a crock of advice that!
Like the car radio it is possible to get interference down the power line and you can get a choke and capacitor set up same same to clean the cable of radio frequency from all the electricals.
There could be unusual noise from badly connected and or earthed devices too. Sourcing bad vibes can be pretty technical but the basic stuff i mention usually does it. the noise I was getting came from the alternator but I dont know whether normal or not. Just setting up properly did it for me.
good luck.
Owen
AnswerID: 211430
Follow Up By: Polaris - Thursday, Dec 21, 2006 at 09:32
Similar experience here with our Barrett 550R and also a Yaesu FT747 ham rig.
Simply relocated the antenna from the bullbar to the rear spare wheel carrier.
I also eliminated the long earth (-) wire that also originally ran directly to the battery and now it has a very short connection to a good body earth. As well as that I ran the positive (+) wire through the cabin and firewall on the opposite side of the vehicle - away from the ECU computer.
Strange and absurd as it sounds - Toyota don't recommend fitting high power RF equipment in their vehicles. This policy is reflected in some model owners handbooks.
FollowupID: 471569
Reply By: geocacher (djcache) - Thursday, Dec 21, 2006 at 01:48
Have a look at the codanoutbackradio group on yahoo. Yahoo login is down at the moment or I'd find you the link.
There's heaps of discussion taken place over the past few years on 100 series and HF interference. Much discussion for possible solutions.
When I was looking at wagons it was enough to put me off buying one.
AnswerID: 211469
