A thought about changing tyre pressures.
Submitted: Wednesday, Dec 20, 2006 at 19:25
4wdNewbie
Hey guys, I had a brainwave the other day and was wondering if it has perhaps already been done or maybe just cannot be. So here goes...
Even a newbie like me knows that different terrains require different tyre pressures. Lets call the max you want it 48psi and the min is maybe 12psi. My idea is kind of like fitting an air tight area that is connected to each rim that is openable and closable depending on what pressures you want the tyres at. So if you had the tyres at 48psi and wanted 36psi, you could turn it down from inside the car (like on the dials at the servo automatice air pressure thingos).
Could that work?
Cheers, Anand.
P.s. And no im not lazy... just innovative. :P
Reply By: Willem - Wednesday, Dec 20, 2006 at 19:49
Mate, unfortunately you are a few years behind the times with your ideas. :-(
Chet Cline in Moe Victoria sells such a unit. Phone number 03 5127 5339
I have seen it fitted to Troopcarrier
Hummer vehicles have a similar system in place.
You can also buy a device which will show your tyre temperature and tyre pressure
Keep on thinking as that is how things are inevnted :-D
211410
Reply By: 4wdNewbie - Wednesday, Dec 20, 2006 at 19:57
haha least im on the ball... better luck next time ey :P
211412
Reply By: Ozrover - Wednesday, Dec 20, 2006 at 21:28
Goodonya Anand.
Lateral thinking is where new inventions & processes develop, without new ideas, or even older ideas re-thought out, the world would be a boring place.
Keep thinking up new & or better ways of doing things & you won't be a newbie for long!
8 )>
211439
Follow Up By: 4wdNewbie - Wednesday, Dec 20, 2006 at 23:02
Cheers Jeff, Just made my day. 8 D
471523
