Toyota Blizzard info required
Submitted: Friday, Dec 29, 2006 at 10:14
ThreadID: 40700 Views:5105 Replies:3 FollowUps:7
Hi folks, a lot of you will know I have a project car (Toyota Blizzard 2.2 n/a diesel).
I am interested in people's opinion as to tyre size, will 33's be too big and suck too much power from this small powerplant? It only has a top speed of 80-85kph so maybe the gearing is OK for 33's in this instance???
I am thinking of adding some drop shackles from Superior engineering and am also interested in peoples opinion of these products or if there is other manufacturers selling similar equipment.
Thanks in advance, Trevor.
Reply By: GaryInOz (Vic) - Friday, Dec 29, 2006 at 16:59
Do a search for Daihatsu F10 or F20 (?) elsewhere and you might have better luck (Toyota simply rebadged the Daihatsu product).
Try www.outerlimits4x4.com in the Daihatsu section as a starting point.
AnswerID: 212423
Reply By: Mark & Jo*Teabags&Teacup* Bris - Friday, Dec 29, 2006 at 23:53
G Day Trev!
Glad to see Blizzard is still on the top of the things to do list!
AnswerID: 212472
Follow Up By: Mark & Jo*Teabags&Teacup* Bris - Friday, Dec 29, 2006 at 23:54
I don't get it.. I changed rig pic photo and it is still coming up with this photo???
You have a good Christmas Trev?
FollowupID: 472731
Reply By: Member - Michael G (QLD) - Saturday, Dec 30, 2006 at 13:31
I had a Blizzard about 7 years ago.I had standard rims and tyres on it.I am amazed that you can only get 80-85kph top speed.Even when I was fully loaded I had no trouble reaching and cruising on the speed limit.I took it to Fraser Island once with a trailer hoohed up and I still could cruise at the limit.The hills slowed me down though.
Mike
AnswerID: 212508
Follow Up By: Trevor R (QLD) - Saturday, Dec 30, 2006 at 20:37
Hi Mike,
Mine is only a 4 speed so if yours was a 5 speed then there's the difference. I really just want to turn this beast into an offroad weapon, which is why I was curious as to the 33' tyres and drop schackles. It had no probs up Teewah beach just before xmas, so now I have a bit more faith in the car's reliability, the work will begin.
Thanks for your input, happy new year.
Regards, Trevor.
FollowupID: 472786
Follow Up By: madfisher - Sunday, Jan 07, 2007 at 22:02
All blizzards were 4 speed. Had same motor and running gear as first series Hiluxs. SAhould do 100ks easy enough . Cousin had one 20 years ago and I thought it would do about 110
Cheers Pete
FollowupID: 474205
Follow Up By: Trevor R (QLD) - Monday, Jan 08, 2007 at 08:43
Thanks Pete,
I have seen some identical Diahatsu cars with 5 speed boxes but they don't have the driveline handbrake like mine so unless I do big changes I can't slot a 5 speed in mine. My speedo tells me at 90kph (80 by my GPS) the car is revving at 3600rpm and it feels and sounds like it LOL!! For any length of time that just seems cruel to me??? Maybe something amiss with mine???
Cheers Trevor.
FollowupID: 474251
Follow Up By: Member - Andrew W (SA) - Monday, Jan 08, 2007 at 09:07
maybe someone has put a lower geared setup ...
FollowupID: 474254
Follow Up By: madfisher - Monday, Jan 08, 2007 at 12:05
Hi Trevor,
We would have only been going off the speedo them days,. My 4runner is also pretty optermistic when it comes to speedo readings. Your currant tyres would be about 28in?. I would try 31s first as I think tou will need a big increase in power for 33s.We just went from 265 70 15 to 10rs which is a similar tyre but l.t. and 75 profile on Sals Pajero and I could not believe how much string it took out of 4th especially towing the boat. If you give me your email address I can send you Phills Ph. no. as he had a blizzard for years and loved it
Cheers Pete
FollowupID: 474270
Follow Up By: Trevor R (QLD) - Monday, Jan 08, 2007 at 12:47
Andrew, that's a real possibility the way this thing drives.
Pete, try me at dieseldrifter at bigpond dot com
Thanks,
Trevor.
FollowupID: 474277
