One for Toyota Turbo Gurus (gurii?)
Submitted: Saturday, Jan 06, 2007 at 16:28
Ian from Thermoguard Instruments
Hi all,
I'm not right up my Toyota engines so, when I just looked at a 78 series Troopy with a N/A 4.2 diesel (1HZ), I was surprised to see a diaphragm chamber on the top of the VE-type injection pump. The chamber has no hose connection to the top of the diaphragm.
So, you Toyota technical gurus out there, do you know:
a ) Is it an unused manifold pressure compensator (and do Toyota therefore use the same pump on the 1HD-T and 1HD-FT factory turbo engines and simply fit a different diaphragm cover?
or b) Is it just an aneroid diaphragm for high altitude fuel correction?
If a) is true, do some/all aftermarket turbo kits provide a new diaphragm cover with a boost pressure connection?
Reply By: Member - DOZER- Saturday, Jan 06, 2007 at 17:20
B high altitude correction for emmissions...
213663
Follow Up By: Ian from Thermoguard Instruments - Saturday, Jan 06, 2007 at 17:29
Ta muchly, Dozer.
474003
