wiring fridge
Submitted: Saturday, Jan 06, 2007 at 17:12
slush
OK, this is what ive come up with. run 4awg from battery to rear of patrol to anderson plug. then 6awg from anderson plug to the two 95 anp/h batteries.( in parallel) from 2x95 amp/h batteries to fridge using more 6awg auto wire
I will use a 30 anp breaker at each end.
Reply By: Mainey (WA) - Saturday, Jan 06, 2007 at 19:50
........use same size wire ALL THE WAY.
213697
Reply By: Crackles - Saturday, Jan 06, 2007 at 22:31
Slush are the 2 x 95ah batteries fitted in a caravan/camper via the Anderson plug or in the Patrol??
Cheers Craig......
213727
Follow Up By: slush - Saturday, Jan 06, 2007 at 22:40
there in the caravan
474050
Follow Up By: Crackles - Sunday, Jan 07, 2007 at 17:21
Slush you probably should fit a battery isolator in the car to avoid flattening the start battery if the van is left connected. I would use no smaller than 16mm squared cable (not sure how that relates to awg) from the car right through to the van batteries to minimise voltage drop with a 6mm cable to the fridge through a 20amp blade fuse. Depending on the type of battery isolator a 30amp CB should be big enough.
Cheers Craig..........
474139
Reply By: brett - Sunday, Jan 07, 2007 at 17:30
One problem I can see is the 30A breaker, those 2 X 95A batteries will pull far more than 30A when flat, probably at least 60A for both. I'd use at least 100A breaker between main battery and the 2 X 95A ones. And if you run 4awg to the plug why not 4awg to the battery no point in dropping to 6awg. Use 6awg to the fridge if you like.
213843
