15amp leads
Submitted: Sunday, Jan 07, 2007 at 13:32
ThreadID: 40957 Views:2448 Replies:5 FollowUps:7
reading on another post about it illegal to have 15amp leads with 10amp plugs, im most confused. while at the hard wear store to day the had them for sale.
Reply By: Shaker - Sunday, Jan 07, 2007 at 13:35
I would have thought that it would be more likely the other way round.
AnswerID: 213819
Reply By: Tony Middleditch - Sunday, Jan 07, 2007 at 13:37
A 15 amp rated flex cable with 10 amp plugs & sockets fitted is OK. Means less voltage drop.
A 10 amp lead with 15 amp plugs & / or sockets is not ok.
Cheers Tony, Registered Electrical contractor
AnswerID: 213820
Reply By: equinox - Sunday, Jan 07, 2007 at 13:52
I'm with Tony, though I might add a mixture of 10A and 15A plugs and/or sockets is not OK.
Caveat Emptor--
There may be some honest salepeople around, but they are few and far between.
If it is found to be illegal, it may be a good chance for some cheap bribery money. Otherwise, you could always report them to the State Electrical Licensing Authority. Gee, that could go all the way to customs!!!
AnswerID: 213822
Follow Up By: slush - Sunday, Jan 07, 2007 at 13:59
reading the packet it says, Heavy Duty extension lead. 15amp lead 10 amp pin and plug, approved to Australian standards Q060739.
FollowupID: 474121
Follow Up By: equinox - Sunday, Jan 07, 2007 at 14:06
Description seems OK, though I cannot locate the standard on the Australian Standards Website.
FollowupID: 474122
Follow Up By: Member - andrew B (Kununurra) - Sunday, Jan 07, 2007 at 14:54
As mentioned above, as long as the plugs on each end are the same, and they don't exeed the rating of the lead, all is ok. Putting a 10 amp male on one end and a 15 amp one on the other so you can plug a 15 amp applience (caravan) into a 10 amp power point is the type of thing the authorities don't like. aA 10 amp plug on both ends will require a lead of at least 10 amps in between, 15 amps is OK in this case.
Cheers Andrew
FollowupID: 474128
Follow Up By: Max - Sydney - Sunday, Jan 07, 2007 at 16:55
Equinox - AS3000 - copst about $98!
Max
FollowupID: 474137
Follow Up By: equinox - Sunday, Jan 07, 2007 at 17:11
Yeah I know of AS3000 (with the purple cover), just haven't heard of Q060739, which Slush mentioned :)
FollowupID: 474138
Follow Up By: Ken - Sunday, Jan 07, 2007 at 17:26
"Q060739"
Doesn't sound like an Australian Standard to me. Maybe some past Queensland power authority approval ??
According to the other forum it is illegal to have a 10 A plug and 15 A socket unles some approved form of current limiting device is fitted.
I reckon there would be hundreds in use as not many people have 15A outlets at home and using it to keep a battery charged and the occasional light to find something left in the van, would be no problem. Provided you didn't use such a lead to run an airconditioner, and other high current appliances.
Probably another bit of 'protective legislation' based on the assumption that everyone is a fool.
FollowupID: 474140
Follow Up By: disco1942 - Sunday, Jan 07, 2007 at 19:25
For further info on the standards and legal situation refer to Site Link
FollowupID: 474164
Reply By: Kazza055 - Sunday, Jan 07, 2007 at 17:28
The subject of illegal 10 to 15A leads has recently been thrashed out on Caravaners Forum ( Site Link and I posted the following reply (among many others). I hope you all jump onto your email and send one as well.
"If you NON BELIEVERS really want to do something to sort this problem out, how about you all contact Arlec and raise it with them as I am certain if they have enough people enquiring about it, they will look into marketing a product that will help you.
To change the rules is not an option, so do as I have done and put pressure onto the people that can produce the product that we all need.
I sent my email to techenquiries@arlec.com.au and had an answer within half an hour. It has now been passed onto their R&D section. The more these people hear about our need the more likely they will listen and react on or requests."
Bob Cheers
AnswerID: 213842
Reply By: Member - Arkay (SA) - Monday, Jan 08, 2007 at 08:46
Also check out Post 32819 April 2006 on this site. Lots of guff, or was that where you started from?
AnswerID: 213947
